what all do i need to run/install Lt1 fans?
im fixin to get some off ebay and was wonderin what wiring will i have to do . could i just hookem up to my fuse box or battery with a toggle switch ? also what about the wiring harness?
I got my wiring harness from nelson. It has a wire that goen into the pcm.
I'm in the process of doing mine and its alot more expensive than I thougt it would be. I ended up needing a bigger alternator, replacing the big 3 wires, getting a tune, thermostat, and then I will have to go get my crank relearn flashed.
And I thought this was gonna be a $200 mod. hahaha
dont use a vsc because they suck and break on everyone
buy a good wiring harness like the one from nelson performance.great quality and install is a breeze. the harness and fans are all you really need. alternator is optional(but strongly suggested). youll have to fab up some small brackets to mount them up. if you go with allens harness youll need to have pin42 turned on in your pcm.
Originally Posted by getchusum99
White1 How Does The Temp Switch Work? And What Other Wiring Will I Have To Do To Run The Fans? Jmust A Power/ground?
When the temp gets to setting, it energizes a solenoid and turns both fans on, and when it drops, they turn off. It comes with most of teh wiring, but I had to extend the wire to the a/c compressor. PM me and I'll let you check them out one day when youre in town
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
Wrecker 426
Sep 30, 2015 09:39 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
