What air temp range makes the best power?
The colder the better. If its extremely cold, the far left side of the IAT spark adder table that you never pay attention to may come into play. For what is enough timing at 70 degrees probably isn't enough at 30 degrees.
pay more attention to density altitude than the temps. it's a combination of temp and humidity. dry cool air is great. damp cold air not as much. also, damp cold air makes for shitty traction. you can usually just go off of the hoods on parked cars. once the roof/hood/bedsides start beading up, the racing is going down hill.
Most dynos run corrected numbers so you can get accurate comparisons if you dyno in december then make changes and dyno again in july. you can see the uncorrected numbers, but if you are looking for a number to work off of you need to see the corrected numbers so you dont always wait for the perfect day to dyno.
I'm in dfw area so its some what close to sea level here, but most days are dry air except rain season gets pretty humid
bsgiffor
Jul 19, 2015 11:14 AM
