welding stainless to steel
Old May 1, 2007 | 09:25 PM
Default welding stainless to steel
my buddy got stainless cats, can I just use my MIG to weld them into the ORY pacesetter sent? or does it have to have a certain gas. Im hopin not and its just more the heat settings.
Old May 1, 2007 | 09:30 PM
KevinF56's Avatar
some guy is making you weld cats to his ORY? what an *******.
Old May 1, 2007 | 11:57 PM
YenkoST's Avatar
The usual stuff to weld steel to steel is just fine. You don't need anything special to do it unless it was stainless to stainless, etc.
Old May 2, 2007 | 12:04 AM
jf-03-ss's Avatar
Use SS wire to weld SS to steel.
Old May 2, 2007 | 06:23 AM
ok i got two different answers now...
Old May 2, 2007 | 09:16 AM
Tig's Avatar
Tig
To weld SS to steel, you should use SS filler rod or wire.
It is possible but not recommended to weld SS with regular mild steel wire.
You would also need a Tri-Mix gas for SS Mig welding.
When were you planning on doing this?
Old May 2, 2007 | 10:10 AM
soon, we got a lincoln welder for welding galvinized fence pipe. i believe i had used to weld stainless, its only two welds so Im not going to buy all that for just two welds, sounds like itll be fine if I weld em with what I got.
Old May 2, 2007 | 11:12 AM
Tig's Avatar
Tig
Thats cool.
Just wondering how soon, I have a Tig welder. But, my generator is on the fritz.
If I can get it running I could swing by and zap it for you.
Old May 2, 2007 | 11:19 AM
where do you live? cuz I could deff use your expertise in the future. if your interested.
Old May 2, 2007 | 11:44 AM
Tig's Avatar
Tig
I'm in Waltham.
Sure.
