welding stainless to steel
Old 05-02-2007, 12:39 PM
oo alright PM me your number, your dont have AIM do you?
Old 05-02-2007, 01:21 PM
kbracing96's Avatar
When you weld ss to mild steal, the best way to do it is with a tig and 309 filler rod. 309 filler rod is for welding dissimilar metals such as ss to mild. It works quite well, I just finished doing this on some of the turbo header parts for my dads truck. 308 rod is for ss to ss.
Old 05-02-2007, 03:25 PM
Tig
Tig's Avatar
No AIM, you have mail.
Old 05-03-2007, 08:30 PM
2LEGIT's Avatar
You can use CO2 for the SS, works great. helps cool the puddle as you go. dont do downhand and watch out for the flux breaking off after you lift your helmet, i've had it in the face and near my eyes b4.
Old 05-03-2007, 08:54 PM
Tig
Tig's Avatar
CO2 is in both mixes for Mig welding SS.
There is 75/25 mix which is 75% Argon and 25% CO2, thats good for single passes. For best results, you want to use a Tri Mix. Dont quote me on this but I think I'm pretty close to what % is used in Tri Mix. Argon 7.5%, CO2 2.5% and Helium 90%.
Then of course you have staright Argon for Tig welding SS. Which you can also Purge your welds from the insde if you are welding tubing. I am pretty sure you can use Helium or CO2 for more penatration when Tig welding to, thats for structural welding.
Old 05-03-2007, 10:16 PM
2LEGIT's Avatar
I dont know anything about tig, haven't gone for my next welding ticket yet. Just got started in the trade about 3 years ago. it's amazing how much the ss weld shrinks as it coolsruns like water but damn does the bead ever look good.
Old 05-04-2007, 08:20 AM
Tig
Tig's Avatar
I love SS welding, especially Tig. Stick is very nice to weld as well, once you get the heat set, you can run a bead like a Tig weld. Very clean
Old 05-06-2007, 10:42 PM
cvman's Avatar
I got lazy one time and welded a stainless 3 inch tube to a steel muffler with a steel mig machine and it's been holding up for 7 years! I just didn;t want to drag out the tig machine...................
Old 05-07-2007, 04:10 PM
Baltimore Whore
Mangled03gmc's Avatar
If you are mig-n it u can use the reg steel wire that you have, it will turn out great..
Wolftrk99
12-03-2015 08:12 PM
blown02408
10-01-2015 01:06 AM
Rockrz
09-29-2015 09:07 AM
lxcoupe
09-25-2015 12:36 PM
Quick Reply: welding stainless to steel
