weiand street warrior intake results!!!!
Old Sep 15, 2008 | 07:57 PM
Default weiand street warrior intake results!!!!
https://ls1tech.com/forums/showthrea...4#post10113304
Old Sep 15, 2008 | 09:01 PM
TXsilverado's Avatar
hrmmmm. still on the sidelines.
Old Sep 15, 2008 | 09:12 PM
looks like its a alot better on the ls2's and 6.0's then the ls3 and ls7's
Old Sep 15, 2008 | 09:30 PM
the test is good and all but i want to see it on a heads cam ls1 or 6.0. those were nice gains on a stock motor but it doesnt tell the entire story. put a cam in there that will pull high rpm's and lets see where it falls off and how ugly it gets down low...
Old Sep 16, 2008 | 10:00 AM
Smitty's '04 GTO's Avatar
What I infer from this is that it works better on the smaller cubes that don't breathe as deep, which bodes well for our 5.3's...
+30 lbs/Ft torque in the midrange on a stockish catherdral port head seems to me to be right up the alley of a truck application where we're moving lots-o-weight or heaven-forbid, some of us actually tow with our trucks...
Either way, I appreciate the testing that Mast Motorsports has done!
I've been eyeing this intake for my Goat in a road track application but if for some reason I'm not quite satisfied, perhaps I could slap it on the Mule and see a benefit!? I wonder what fitment issues may exist for the Street Warrior on a truck application - the same as when using the LS6 intake on trucks? I hope not...
Old Sep 17, 2008 | 11:15 AM
it will most likely be like a ls6 intake swap. relocate idle pulley, cut alternator bracket, modify/new water pump and new injector plugs. its not a bad swap just tedious.
Old Sep 17, 2008 | 11:57 AM
hirdlej's Avatar
Will they make one for a truck 78mm tb?
Old Sep 17, 2008 | 12:13 PM
it comes with an adaptor to use the 78mm tb.
Old Sep 17, 2008 | 01:24 PM
hirdlej's Avatar
Now I'm all ears........ Riddle me this, will my 44 lb/hr injectors work with it? If so I'm willing to do the swap
Old Sep 17, 2008 | 05:25 PM
Wilde Racing's Avatar
How do I change this text
if you custom make the rails....
I'm more interested in the dual plain edelbrock and twin quad set-up for FI...
