want to make 400 whp with 6.0
I'm new to this forum and i swaped an LQ4 into a 72 GMC truck with a 700r4 behind it. I had it dyno tuned and the numbers were a bit disapointing 323rwhp and 342tq. it runs a 13.6 @99 and what i want is to run about a 12.9 or so and put down 400hp. It has the hot cam 525lift 218 in and 228 ex with 112lsa, long tube headers ls6 valve springs and truck intake manifold. power peaked at 5K and stayed flat till 6k. I am thinking about going with a fast truck intake along with a 90mm throttle body dbw, and changing the cam i read bad things about the hot cam thinking of a tr 224 with 112 lsa, i like the lope and don't need to pass emisions even in cali due to the year any suggestions i've built a few gen 1 small blocks but am new to ls engines thanks also gear ratio is 3.5 ford 9in rear, numbers were with converter locked by switch, 275/60 r15 tires steel rims thanks
tr224 and PRC ported stage 2.5 5.3 heads
no way i would spend all that money on a fast intake setup...heads are the same price and will out perform an intake manifold
400hp look up truckshop he has a dyno of his 6.0 setup like this
considering the cost of the FAST 102 setup, i agree. send your heads out to TEA or AI and let them run their CNC program. it will cost just a little more but give bigger gains. have them milled to bump your compression and have a professional spec your cam to match the heads. i had no problem getting my smaller cubed LS1 over 400 HP using the truck manifold and some low budget heads.
thanks for the replies i was thinking about doing heads but when i looked at the graph and saw the flat line i was thinking maybee it's the intake holding it back i saw carcrafts lq4 build with the same cam and it made 480 at the crank i know things might be a little inflated for advertising but i didn't think that much and for the compression i didn't think a half a point was quite that big a deal and also i can only get 91 octane fuel another question is the 90 mm throttle body necesary to make that power in wich case i would have to swap intakes anyway but might go with a cheaper truck intake with 4 bolt pattern, and txsilverado did you have the 90mm throttle body on your ls1 with the truck intake
