walbro gss 340 hold pressure?
Old Jan 7, 2007 | 12:01 AM
blown3qtr's Avatar
Default walbro gss 340 hold pressure? ( UPDATE )
Should a walbro gss340 intank pump hold pressure w/ key off like a stock pump?
Old Jan 7, 2007 | 01:29 AM
TurboGibbs's Avatar
Mine does.
Old Jan 7, 2007 | 01:58 PM
blown3qtr's Avatar
Thanks
Do you know if there is a check valve in the pump itself or is it in the module assembly?
Old Jan 7, 2007 | 02:25 PM
TurboGibbs's Avatar
It has to be in the pump since I have bypassed everything else in the module assembly.
Old Jan 7, 2007 | 07:22 PM
blown3qtr's Avatar
Thanks again.
I was talking to my buddy in more detail today about it. I think he F'd up the flexible fuel line in the module. It is running good but pressure bleeds off fast when the pump is off.
gibbs, congrats on getting your motor together.
Old Jan 20, 2007 | 12:53 PM
blown3qtr's Avatar
Just wanted to Update for anyone that might be interested.
There is a check valve in the outlet of the walbro pumps. If you are not careful when you pull off the rubber cap on the end the retainer might come of w/ it. The valve can fall out then, or get lodged in the hose. Either way you are SOL.
TAPyvehc93
Jan 8, 2016 10:47 AM
Chavette
Oct 28, 2015 07:33 PM
murderedSS
27
Oct 12, 2015 11:13 AM
chevstang421
Sep 10, 2015 09:16 AM
slowswb
Sep 5, 2015 02:27 PM
