Radix 9psi kit, how much power with my mods?
What kind of power would I make if I get a Radix and run it at 9psi? The mods are in my sig. Also planed is yank 3k, 4.10's, and if I'm still not happy a 220/220. It will always be a daily driver and I tow quite a bit with it.
Thanks for the help.
I would say in the 400hp range. If you did a cam i would go with more of a blower cam. With a cam and the other bolt ons its had to say but i would say that you would be well into the deep 13s maybe high 12's. You can lose if you go with the radix with the intercoooler and a good blower cam. Go for it you wont be disapointed. Trust me. Your mpg will go down alot when you cant keep your foot out of it
Originally Posted by 2004Denali
I would think he would be in the mid 12's
I am running 7.5 psi @ 6000lbs doing 12.8 in the 1/4 with pretty much just bolt-ons
Mark
Mark
You dont have a stall either? Those 60' times are sweet. What gears are you running?
No stall needed for just the radix. If you get a cam i would go with a 2600 so you still stay in the radix powerband. I dont see you having any problems hitting that with a radix and a cam.
stock brake stall right now is 2100rpms. With the radix it should go a little higher, maybe 2300-2400. Maybe the stock one will be ok. I just dont want to mess with towing capacity much, i have a big boat and my blazer would die trying to pull it.lol
zaathur151
Jul 6, 2015 10:57 PM
