Walbro 255 fuel pump ??? (after install)
Old Mar 25, 2008 | 08:35 PM
dlt76028's Avatar
Default Walbro 255 fuel pump ??? (after install)
I just installed a walbro 255 pump GSS340M and now when i get in the truck i cant just turn the key and start it like normally now i have to turn the key on for a few seconds and wait and then the starter will kick over a few times and then it will start up? anyone else have this issue with the swap?
Old Mar 25, 2008 | 08:40 PM
tarinitup's Avatar
9 Second Truck Club
happened to mine too. It's a faulty check valve on the pump. I have run mine for over a year with no problems exept on start up.
Old Mar 25, 2008 | 08:56 PM
dlt76028's Avatar
well that sucks... you buy something new and you kinda expect it to work properly.
Old Mar 25, 2008 | 09:03 PM
hirdlej's Avatar
Why did you upgrade your pump?
Old Mar 25, 2008 | 09:21 PM
dlt76028's Avatar
it was getting a little lean up top and that annoying whinning.
Old Mar 25, 2008 | 10:03 PM
TurboJohn6's Avatar
That could definately be the problem. I was told when I purchased my Walbro pump that I could have an issue with extended cranking during start up. I purchased my pump from an authorized Walbro dealer and he stated that I might have the same problem you are describing. That is why Walbro does not list a part # for our trucks. This is what I was told anyway. Fortunately I did not have that problem with my truck. FYI!
Old Mar 26, 2008 | 12:09 AM
brodystruck's Avatar
I always heard it was the check valve too, my Walbro thankfully doesn't have that problem...
Old Mar 26, 2008 | 12:02 PM
dlt76028's Avatar
WOW. now my check engine light is on... who knows why this time. all i did was change the pump
Old Mar 26, 2008 | 01:29 PM
dlt76028's Avatar
codes p0135 p0327
Old Mar 26, 2008 | 02:58 PM
joe06ss's Avatar
i have had the same problem... no other problems though so i let it be...
