vsc controller and efans
Old Aug 22, 2003 | 09:12 AM
goshawk23's Avatar
Truck addict
Default vsc controller and efans
my fans got put on yesterday and i was wondering, at what temps are you guys' fans kicking on. I know the vsc is variable, but it seems that mine take forever to turn on. much like the stock clutch fan. Anything we can do to change the wiring other than running a manual kick on switch. i am not opposed to doing that but would rather see if there is another way. might just take the vsc off completely. fans are ls1 and temps are at the normal range.
Old Aug 22, 2003 | 12:10 PM
Flyer's Avatar
Default Re: vsc controller and efans
I know mine is turned all the way down, so it will turn on at the coolest temperature. I still don't think that is enough, but I guess it's all we have to work with.
Old Aug 22, 2003 | 12:57 PM
goshawk23's Avatar
Truck addict
flyer, were did you put that thermostat sensor at? we put mine in the radiator. wondering if there is a better place.
Old Aug 22, 2003 | 03:20 PM
XLR8NSS's Avatar
Adkoonerstrator
Mine come on around 185°. They could come on cooler but, I don't want the fans running all the time so I set them higher. That little sensor that pushes through the radiator is in a spot to read the hottest coolant entering the rad. You'd need to put it somewhere hotter to get the fans on sooner. Kinda like tricking the VSC into thinking the coolant is hotter than it actually is.
You might be able to wire a resistor in the probe line to trick the VSC like this but, you'd need to test the resistance on the wires to see what one might be appropriate.
Old Aug 22, 2003 | 03:52 PM
BigKID's Avatar
Thats what I was thinking.
Old Aug 22, 2003 | 03:56 PM
goshawk23's Avatar
Truck addict
Hmmm, Thats all you kenny.
Old Aug 22, 2003 | 04:13 PM
XLR8NSS's Avatar
Adkoonerstrator
Great minds think alike.
Old Aug 22, 2003 | 04:43 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
But fools seldom differ
j/k Sorry, couldn't help myself :p
Old Aug 22, 2003 | 04:53 PM
XLR8NSS's Avatar
Adkoonerstrator
Ok back to the topic.
Old Aug 22, 2003 | 08:23 PM
goshawk23's Avatar
Truck addict
thanks for the info xlr8nss. I think you only confirmed what BigKID was already thinking. As for myself, i don't have a clue.
Porscharu914
14
Jan 20, 2016 10:45 AM
Avalanche2002
Nov 30, 2015 07:31 AM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
