Vortech's H2 supercharger + other new kits
Old Jun 26, 2003 | 12:12 PM
tbyrne's Avatar
Default Vortech's H2 supercharger + other new kits
Vortech has just released their H2 supercharger for the 2003 H2. The addition of the V-2 SQ S-Trim supercharger will increase horsepower from 316 to 436 and torque from 360 lb./ft. to 465 lb./ft. at 7-8 psig at the flywheel.
The system includes an integrated dual-pass air/water charge cooling configuration, which features a closed loop water cooling system with a stand-alone pump, tank and front mounted heat exchanger. All components needed to bolt the system to a stock vehicle, such as cast aluminum mounting bracket, fuel system upgrades including high-flow fuel pump and replacement injectors, supercharger oil feed and drain, compressor bypass valve and all required fasteners are included. The installation allows retention of all factory accessories including A/C and power steering. This system is available in satin or polished finish and is 50-state smog legal under CARB EO #D-213-19. The V-2 supercharger is covered by a three-year limited warranty.
Our regular retail prices are -
4GL218-070SQ
2003 H2 Vortech H2 supercharger with satin finish
$4799.99
4GL218-078SQ
2003 H2 Vortech H2 supercharger with polished finish
$4999.99
They have also added new kits to the 1999-'03 line-up including the 2003 5.3 and 6.0. Those part numbers are -
4GL218-010SQ
2002 4.8 kit with satin finish
4GL218-030SQ
1999 5.3 kit with satin finish
4GL218-010SQ
2000-'02 5.3 kit with satin finish
4GL218-010SQ
2000 6.0 with satin finish
4GL218-040SQ
2003 6.0 with satin finish
4GL218-050SQ
2003 5.3 kit with satin finish
4GL218-018SQ
2002 4.8 kit with polished finish
4GL218-038SQ
1999 5.3 kit with polished finish
4GL218-018SQ
2000-'02 5.3 kit with polished finish
4GL218-018SQ
2000 6.0 with polished finish
4GL218-048SQ
2003 6.0 with polished finish
4GL218-058SQ
2003 5.3 with polished finish
E-mail tbyrne@tbyrne.com for any supercharger discounts.
Tom
lsxperformance
Apr 20, 2016 12:17 AM
2500ZL1
Jan 25, 2016 06:30 AM
echoman
Aug 22, 2015 01:53 PM
blownss27
Aug 14, 2015 03:31 PM
blownss27
Jul 20, 2015 08:59 AM
