Volant or Spectre CAI
Old May 13, 2011 | 02:44 PM
  #41
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by KLUG'S SS
Yeah my buddy Craig known as sonoma43 on here, his K&N fits really tight up against the shroud on his 03 Silverado.
He might want to "clearance" the shroud a little bit if it's as tight as mine was...there was just enough room to slip a piece of paper in on mine, but when I powerbraked the truck the engine would lurch forward and actually contact the shroud. I'm sure that if that happens enough times, something is going to crack eventually. A nice set of efans will definitely fix any clearance problems though
Old May 13, 2011 | 04:38 PM
  #42
offroadrider12's Avatar
Not that efans wouldn't be nice, but I appreciate the simplicity and ruggedness of the mechanical fan. No relays and junk to burn out. It works like it should all the time.
Old May 14, 2011 | 03:37 PM
  #43
budhayes3's Avatar
PT's Slowest Truck
...as long as the fan clutch doesn't leak or go bad otherwise, but yes, the factory clutch fan does perform as it should. Knock on wood, I've had good luck with my efans...I did have 2 relays go bad last summer (after over 5 years of service), but I put 3 new ones in and keep 3 backups in the glove box just in case
Aaron Arceneaux
Dec 21, 2015 02:54 PM
cheyenne383
Nov 13, 2015 09:24 AM
gaps
Oct 15, 2015 02:53 PM
bluebommer07
Sep 20, 2015 08:42 PM
nickrench3
Sep 17, 2015 08:48 AM
