Vinci High Performance "041" Cam
Old Apr 20, 2006 | 03:20 PM
Yelo's Avatar
Default Vinci High Performance "041" Cam
Specs are: 228º/236º .600/.600 114 on Crane lobes, go to www.cranecams.com and look up part number 144HR00041 for complete cam specs. I'm cusrious if anyone here has a sound clip/dyno chart....or a clip/chart of a similar cam ??
This is the one I'm leaning towards in a BIG way once my PRC LS6 heads get here, I've been researching a little and most seem to think this will be a good "compromise" cam, meaning it will work good both NA and FI. I'm going to be limited on the boost I can run anyway with the 10.4:1 CR I'll have (yet another compromise between NA and FI) so I'm not too worried about the boost-bleed that will probably occur with this cam....
Old Apr 20, 2006 | 06:10 PM
bluecajun5.3's Avatar
11 Second Truck Club
good luck. seems like a lot of duration for a big truck
Old Apr 21, 2006 | 01:58 AM
Yelo's Avatar
My 044 (210º/218º .531/.531 114) has so much torque that I spin even on part-throttle takeoff's, I'd be happy to lose a little bit if I could gain it up top. The 4.10's are going to help me out a bit even if I'm down on torque
Old Apr 21, 2006 | 04:45 AM
sweet. i'm in the same boat as you on the low end.
Old Apr 21, 2006 | 05:54 AM
Silver-Dollar's Avatar
Must be nice to have that problem.
Old Apr 21, 2006 | 07:27 AM
98TAauto's Avatar
i'd get a 220 or 224 cam biggest but thats just me.. thats bigger than my fbody cam(228/230) and that suks for daily driving sorta..
You are gonna loose some low end with a 224 cam so that might be whatcha want. I wouldnt go so dang big that you loose to much down low.
Old Apr 21, 2006 | 11:05 AM
Yelo's Avatar
Remember I'm looking for a good "compromise" cam....something that will work ok both FI and NA, I tend to think this is a little too large for a DD as well but more and more people are driving HUGE cams every day and seeming to think they do just fine in our heavy *** trucks, I know of at least two people that are running (or going to run) MS3's in 6.0's.....one in a lifted 4x4 and he says he loves it !!
Old Apr 21, 2006 | 01:35 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I ran a cam very similar to that (and still do except for the reverse split). mwalls is now running my old cam in his 408 (230/236 .60x/.61x on a 114) and I think he has some sound clips up. I think Parish ran a similar cam as well in his 6.0.
That's a better s/c cam than a turbo cam, IMO. The forward split was much rougher for me than the reverse split.
KOOKS Headers
Jul 27, 2015 01:43 PM
cbhedrick
Jul 20, 2015 10:12 PM
blownss27
Jul 20, 2015 08:59 AM
Aboss
Jul 9, 2015 10:28 AM
jrplz
Jul 9, 2015 12:07 AM
