Valve Train Issues, What Died First?
Old Dec 18, 2023 | 09:22 AM
zz454Chevelle67's Avatar
Default Valve Train Issues, What Died First?
Damaged Morel 7717 lifter, bearings cam apart in rocker arm, broken valve spring. Not sure which part took out the others but eiother way I dropped a valve on a 17K mile engine, wrecked a head and piston but no cylinder damage. Ordered a set of Jonhson lifters yesterday, piston and rings are replaced. Anyone ever seen a lifter with the retaing clip stuck inside it?
1 bearing is missing from the rocker
Retaining clip wedge between bore and pluger.
Old Dec 18, 2023 | 10:11 AM
MikeGyver's Avatar
You have to be a gambler to use single coil valve springs. I had a double coil outer spring fail with the result being a loud tapping noise, and I had a single coil fail with the result being a completely destroyed engine.
Old Dec 18, 2023 | 10:58 AM
True statment for sure, new spricgs are dual coil.
Old Dec 18, 2023 | 12:04 PM
shakenfake's Avatar
Shlumpt
5 Year Member
@MikeGyver Depends on the application in my opinion.
Old Dec 20, 2023 | 06:27 AM
smokinlmm's Avatar
Why no trunion upgrade?
Old Dec 20, 2023 | 03:26 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Tell us a little more about the combo. cam specs? spring specs?
Looks like a stock push rod and a stock rocker arm?
Old Dec 20, 2023 | 03:35 PM
MikeGyver's Avatar
To me, it doesn't seem like anything in the valve train could break a spring. But I see your point, maybe a mismatched setup?
Old Dec 21, 2023 | 08:49 AM
BTR trunion upgrade installed and ready to go back on.
Old Dec 21, 2023 | 09:14 AM
Cam is Lingenfelter GT2-3, BTR springs but I have had for so long I dont remeber which ones they are, rockers and pushrods are stock.
Johnson 2116LSR lifters should be here today according to UPS traking.
New springs are BTR Platinum Dual Valve Springs.
Looks like rain thru Sunday but I am off next week and should have time to start putting it back together.
Old Dec 21, 2023 | 11:09 AM
1FastBrick's Avatar
Been so long, I had to look that one up.
207/220 duration @ .050 lift -.571/.578 lift with 1.7 rocker 118.5 CL
Other than the LS6 type replacement spring, I don't recall BTR Selling a single beehive unless they were something like a PAC?
Any way I would say based on the picture that the spring it self broke first. Everything after was just a casualty...
Denali08
Jun 19, 2017 02:17 AM
maxx83
Mar 26, 2014 06:42 PM
sickREDsierra
Sep 3, 2008 10:52 PM
Dark Halo
Nov 27, 2005 06:11 PM
ThunderZ28
Oct 30, 2005 01:25 AM
