Which Valve Springs for this cam setup?
Old 08-11-2020, 09:50 AM
jcarl126's Avatar
Default Which Valve Springs for this cam setup?
Hi guys,
Need some help here. PAC 1219X set good for 0.625" lift or 0.660" dual spring setup from Cam Motion?
Cam specs are the 5.3L Titan 3 from Cam Motion,
224/228 113+4 .603"/.595" lift
Truck is going turbo and wont be spun past 7k rpms through a 4L80E
Thank you very much!!
Jeff C.
Old 08-11-2020, 10:39 AM
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
Both will be fine for that camshaft. Some like the single beehive for it's light weight and others like the dual spring for a safety margin if the outer spring brakes. Another good choice is the PSI 1511ML spring. It's a single beehive and I've read there are no reports of this spring failing, not sure this is 100% correct but this is a quality piece.
00pooterSS (08-11-2020)
Old 08-11-2020, 02:15 PM
Drspencer's Avatar
Dual....but I'm suddenly baised. Just broke a beehive valve spring that had a .600 max lift after 35,000 miles on .560 lift and 208/212 duration. Replacing with BTR dual springs.
Old 08-11-2020, 02:27 PM
MikeGyver's Avatar
Single springs are for gamblers or stock cams.
Old 08-11-2020, 02:30 PM
Merctech2's Avatar
kinda like people that run 4l60 in trucks lol
The following 2 users liked this post by Merctech2:
00pooterSS (08-11-2020), JFortner5 (09-21-2020)
Old 08-11-2020, 03:36 PM
100% Redneck
RedXray's Avatar
At 6500+ RPM the inner spring has a lot of work to perform keeping the valve and piston from contact during a spring failure. Still may be enough to minimize damage and salvage something... maybe
I've run the single PAC 1218 good for .600" on a .597" intake lobe with no issues, but for less than 5,000 miles. With the .629" .615" I have now, the dual .660 spring is a must.
Old 08-11-2020, 05:14 PM
00pooterSS's Avatar
Just to jump in there and stir things up. I've seen quite a few broken SINGLE valve springs with NO damage other than the spring.
Single or dual does not always guarantee no damage. Singles are the best for the most stable valve train. Some like to go dual because it gives them peace of mind.
Old 08-11-2020, 05:37 PM
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
Outside the box here, I like the singles because I can replace valve seals with readily avail ones
PAC1219 and LS6 user here
*also still have a 4L60 in my truck
Old 08-12-2020, 10:36 AM
jcarl126's Avatar
hahah lots of conflicting takes on here!
sheesh, not sure which way to go
Old 08-13-2020, 12:25 PM
LS1Tech Sponsor
Summitracing's Avatar
Like Red and Pooter said you can go either way.
We wouldn't hesitate to throw a set of PAC 1219's on the heads for that cam. The 1219X's would gain you another 10 lbs. of seat and open pressure from the standard 1219's.
If you're looking for "peace of mind" a set of Trickflow .660" lift duals would do the trick.
00pooterSS (08-13-2020)
Quick Reply: Which Valve Springs for this cam setup?
