Which Valve Springs for this cam setup?
Old Aug 11, 2020 | 09:50 AM
jcarl126's Avatar
Default Which Valve Springs for this cam setup?
Hi guys,
Need some help here. PAC 1219X set good for 0.625" lift or 0.660" dual spring setup from Cam Motion?
Cam specs are the 5.3L Titan 3 from Cam Motion,
224/228 113+4 .603"/.595" lift
Truck is going turbo and wont be spun past 7k rpms through a 4L80E
Thank you very much!!
Jeff C.
Old Aug 11, 2020 | 10:39 AM
RedXray's Avatar
100% Redneck
Both will be fine for that camshaft. Some like the single beehive for it's light weight and others like the dual spring for a safety margin if the outer spring brakes. Another good choice is the PSI 1511ML spring. It's a single beehive and I've read there are no reports of this spring failing, not sure this is 100% correct but this is a quality piece.
Old Aug 11, 2020 | 02:15 PM
Drspencer's Avatar
5 Year Member
Dual....but I'm suddenly baised. Just broke a beehive valve spring that had a .600 max lift after 35,000 miles on .560 lift and 208/212 duration. Replacing with BTR dual springs.
Old Aug 11, 2020 | 02:27 PM
MikeGyver's Avatar
Single springs are for gamblers or stock cams.
Old Aug 11, 2020 | 02:30 PM
Merctech2's Avatar
kinda like people that run 4l60 in trucks lol
Old Aug 11, 2020 | 03:36 PM
RedXray's Avatar
100% Redneck
At 6500+ RPM the inner spring has a lot of work to perform keeping the valve and piston from contact during a spring failure. Still may be enough to minimize damage and salvage something... maybe
I've run the single PAC 1218 good for .600" on a .597" intake lobe with no issues, but for less than 5,000 miles. With the .629" .615" I have now, the dual .660 spring is a must.
Old Aug 11, 2020 | 05:14 PM
00pooterSS's Avatar
Just to jump in there and stir things up. I've seen quite a few broken SINGLE valve springs with NO damage other than the spring.
Single or dual does not always guarantee no damage. Singles are the best for the most stable valve train. Some like to go dual because it gives them peace of mind.
Old Aug 11, 2020 | 05:37 PM
arthursc2's Avatar
Outside the box here, I like the singles because I can replace valve seals with readily avail ones
PAC1219 and LS6 user here
*also still have a 4L60 in my truck
Old Aug 12, 2020 | 10:36 AM
jcarl126's Avatar
hahah lots of conflicting takes on here!
sheesh, not sure which way to go
Old Aug 13, 2020 | 12:25 PM
Summitracing's Avatar
LS1Tech Sponsor
Like Red and Pooter said you can go either way.
We wouldn't hesitate to throw a set of PAC 1219's on the heads for that cam. The 1219X's would gain you another 10 lbs. of seat and open pressure from the standard 1219's.
If you're looking for "peace of mind" a set of Trickflow .660" lift duals would do the trick.
