Valve float STS
Old Feb 27, 2005 | 11:58 PM
  #21
Stroker 1500's Avatar
Originally Posted by hotrod04
Allen Nelson has sent me 3 pcm's and the forth on the way??
ebay, one of the links to the right, jegs, summit....most places that carry high performance shops... etc etc
Old Feb 28, 2005 | 08:57 AM
  #22
marc_w's Avatar
There is talk of boosted valve float on this page here.
Three quarters of the way down. "Is choosing the right valve springs for Supercharged engines critical?"
Old Feb 28, 2005 | 09:14 AM
  #23
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Don't know how you check the IATs and I have the filter that sts supplies with there kit. Xtreme say's there is no KR. Could I check it out without the Air filter for just a short drive?
Xtreme is most likely logging the IATs. If you are still working on the tune, make sure Allen knows about this issue. I highly doubt its valve float. I spun my stock motor up to 12psi with no float.
Old Feb 28, 2005 | 09:16 AM
  #24
According to that article, because of the 5 psi he is pushing, his seat pressure is reduced by around 20lbs. I wouldnt think that would be enough to cause valve float, especially at only 5000rpm....I still think it is in the tune. I dunno, you should talk to one of the sponsors here. They could give you a definite answer.
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
