Valve float STS
Old Feb 27, 2005 | 03:15 PM
Originally Posted by BlownChevy
------------------> Sponsors on the right
Are the 918 springs from a company like comp cams, or crane??
Old Feb 27, 2005 | 03:40 PM
bluecajun5.3's Avatar
11 Second Truck Club
comp cams
Old Feb 27, 2005 | 04:48 PM
quicksilverado's Avatar
Originally Posted by hotrod04
Did you have the same problem? where do I get the 918 springs?
No, I had the springs long before the turbo.
Old Feb 27, 2005 | 06:03 PM
ronn25's Avatar
I've ran up to 8lbs of boost and no problems on stock springs and stock fuel pump. My truck only has 7,000 miles though.
I can't see you having problems with only 6lbs. but you never know.
Old Feb 27, 2005 | 06:25 PM
Weedo's Avatar
I'm having mine installed at Xtreme tomorrow. I'll let you know if I run into any issues. They're not going to run an intank on mine though. They highly recommend a setup like what comes with the Radix. Did they mention that to you??
Old Feb 27, 2005 | 08:29 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Do you have the little air filter or the big one? What are your IATs? Seeing any KR?
I had a very similar problem when I was tuning at first -- I put on the bigger air filter (I know this sounds like mystical bullshit but it isn't) and it dropped my IATs and elimiated the "falling on the face problem" It was about 100-105* ambient at the time.
Old Feb 27, 2005 | 09:18 PM
I think mine would be like the Radix, it is the Walbro that I bought from sts. 340-255
Old Feb 27, 2005 | 09:21 PM
Don't know how you check the IATs and I have the filter that sts supplies with there kit. Xtreme say's there is no KR. Could I check it out without the Air filter for just a short drive?
Old Feb 27, 2005 | 09:31 PM
I wouldnt think that it would be valve float....Maybe some kind of tuning issue?
Old Feb 27, 2005 | 09:37 PM
Allen Nelson has sent me 3 pcm's and the forth on the way??
