Vacuum Leak...
Self proclaimed VILLAGE IDIOT
As you may know, I got my truck back from the shop a little over a month ago. Ever since then it's been one problem after another...
First it was the TPS sensor.
Then it was the coil packs.
Then it was the knock sensor... Which I replaced last night.
Here's a picture of the new knock sensor compared to the stock #2 knock sensor. The ceramic connector fell apart in my hand when I went to remove it.
NOW it's a ****** vacuum leak.
My best guess is that when I put the EGR valve back on, I didn't seal it completely. So, that's the first thing I'm gonna check.
Update later.
Any suggestions?
Update later.
Any suggestions?
That's gotta be the "nastiest" knock sensor I have seen.
Vacuum leaks can be troublesome to find. Since you took off your intake manifold to change the knock sensor, any chance your gaskets are not seated properly? Can you determine what bank your leak is on?
Obviously I would start to look at the items you messed with first.
I dunno. I think I'm probably just gonna take the intake off again and redo everything... Probably won't be today though.
That is your fuel pressure regulator, and if by "wire" you mean vacuum hose, then by golly you just found your vacuum leak. Other problems like rich idle condition will be solved by reconnecting this tube as well.
Now I gotta replace the #1 knock sensor.
