v2 touquer cam!!! 232 234
Old Oct 11, 2011 | 07:58 PM
05gmcsierra's Avatar
Originally Posted by 364HC
i run a 224R on 10:5 CR 5.3 with heads & 4400 stall... and i love it...
I've seen many 5.3's with TQ-v2 cam, and great results, just keep in mind- that cam will require heads/stall/gear's...
this is more of what u need higher compression heads 4400 stall!!! if not its too big..
Old Oct 11, 2011 | 08:03 PM
kvpaintbal's Avatar
05 sierra,I wanna change the stall to whatever I need u know, and. Later maybe some 410s or lil lower.............................. and364hc, I plan on doing that in time will take me a lil while tho, I already spent alot of my money lol, I wanna later get head work, but for now stall and cam
Old Oct 11, 2011 | 08:07 PM
Tootall's Avatar
You can run a low 13 with a 222/224 .566 .568 -112..... 3,200 stall, and stock gears....
Old Oct 11, 2011 | 08:08 PM
if u plan on going 4000 converter and atleast 4.10s then shoot for a tr224 or tr228, head work might not be needed since the lift isnt more then 600 but milling ur heads to raise compression would be a good idea.. and then yes it would move..
Old Oct 11, 2011 | 08:09 PM
and if u just want mid 13s u dont need much more lol.. im on a 222/226 598/596 111+2 cam and 3600 stall and i went 13.7 on 100+ temp..
Old Oct 11, 2011 | 08:11 PM
what? i must need to go back down lol.. my dam truck only went 13.7 on similar cam more stall more gear...haha
Old Oct 11, 2011 | 08:20 PM
kvpaintbal's Avatar
Well I just wanna go big cam u know, leave from for improvement, I wanna go fast as I can on stock motor honestly, the torquer is a 232 234 588 595, that's less lift then your, BUT bigger intake and exhaust, so gal so biggest to go with stock setup and later heads, is the thunder racing tr 228
Old Oct 11, 2011 | 08:21 PM
kvpaintbal's Avatar
Sorry so yal think the tr 228 , is the biggest for the stock setup?
Old Oct 11, 2011 | 08:23 PM
kvpaintbal's Avatar
I wanna thump also, I know sound don't mean nutn, but I can't wait to leave my truck at the gas pump thumping while a older guy walks buy like wtf hahahaha
Old Oct 11, 2011 | 08:24 PM
if u plan on doing heads later u can push something with 600+ lift... my heads are 799/243 witch flow better then urs.. the lift in that cam is fine just the duration is too much.. so yes 228 would be max if ur planning on slapping a 4k+ stall to get u going.. but like i said just mine opinion... in on 10.5:1 compression 4.10s and 3600 and my cam seems to be loving the set up
