v2 touquer cam!!! 232 234
Is this cam to big for a 5.3, tuner out of houston says its big but not to big, that the other cams are babies! Need help, comment ur oponions plz
On a stock compression 5.3? If so a very poor cam choice for that setup simply due to the fact of that cam in a stock 5.3 with the stock CR of what 9.4-9.5:1 would give you a DCR of around 7.3 or so. That motor is going to feel like a real turd until those RPMs really get up there. Honestly I think you'd be very disappointed overall.
toooo big on a 5.3... im on 10.5:1 compression and i wouldnt go any bigger then what i have.. 222/226 cam on a 3600 stall
What they said above is correct. It's okay to go one step slightly bigger than what you SHOULD put in the engine, but a torquer v2 is too big for a stock 5.3l.. The only way I would put the torquer v2 cam in a 5.3L is if it was a RCSB with better heads and a Tight 4000rpm stall for a strip truck or weekender with a nice set of gears. I would probably do some weight reduction on top of it. The torquer v2 is more for a LS1 in an Fbody camaro.
Are you even planning on an upgraded converter or are you sticking with the stock one? What kind of truck do you have, reg cab crew cab etc? Planning on changing gears or keeping the stock gears? What gears do you currently have? You need to do a lot of research before buying a huge horse dick cam for a 5.3L, especially if its a stock 5.3. Answer some of those questions first then we can recommend a cam that would work fine. |
I have looked alot man, I have a ecsb, 03 5.3. Tuned,headers, ory, magnaflow, built 4l60e, tb converter (2600), 373s with locker, motor is stock, and I was planning on going with alot bigger convertor. Flaco , and chucks, both recommended this cam, said it would be sluggish, until I got the 3600 then it would come alive, I watched a guy on youtube run a 1270 in the same truck, but he did have a 150 shot of nitrous, which would make a huge diff, all of ur guys opinion r helping alot, plz continue helping, cause im worried to screw up on my DD, but also buying a work truck beg of the year, but still want my chevy ddable
Originally Posted by kvpaintbal
(Post 4790724)
I ran a low 14, I would really like to get into mid 13s
Ok man, ill go smaller, what's the biggest I can go, u reckon
(Post 4790734)
i run a 224R on 10:5 CR 5.3 with heads & 4400 stall... and i love it...
I've seen many 5.3's with TQ-v2 cam, and great results, just keep in mind- that cam will require heads/stall/gear's... |
