Update on my plans
Old Feb 17, 2005 | 10:11 AM
Scream's Avatar
MOOBIES Moderator
Default Update on my plans
Just wanted to throw this out there, been kinda boring at work today.
--Finish drivetrain (4L80-e swap, 3.73s, new driveshaft)
--Eagle 383 rotating assy (Eagle forged crank & H-beams, JE pistons)
--Pacesetter headers (if they'll fit w/ the drop), homemade ORY
--head studs
Then, later this year:
--AFR 225's
--TSP 233/239
--FAST or LS6 intake
I'd like to see solid 12s on the first setup, and hopefully w/ the h+c I might could touch 11's N/A???
Old Feb 17, 2005 | 10:26 AM
FILE's Avatar
--head studs
--AFR 225's
--TSP 233/239
11"s N/A....
Old Feb 17, 2005 | 01:21 PM
Sport Side's Avatar
That is such a band wagon camshaft. It came out, so everyone jumped on it. The results I've seen haven't been that substantial. Also note, with a head as efficient as that, you wont need as much camshaft to make the same rpm.
Old Feb 17, 2005 | 01:34 PM
Scream's Avatar
MOOBIES Moderator
From what I've seen it gives a nice, broad torqueband. It's also very close in specs to a custom grind that Cam Motion recommended to me.
What are some other ideas that you have for a nice cam for the 383 setup?
Old Feb 17, 2005 | 01:43 PM
Sport Side's Avatar
Can you post any dyno graphs? Nevermind. I found a few. I did forget that you are stepping up to a 4 inch crank. That'll affect things.. I need to edit my initial post.
Old Feb 17, 2005 | 01:46 PM
Scream's Avatar
MOOBIES Moderator
Car is a 2000 SS, 6 speed - mods are as follows:
Whisper Lid, Hooker LTs, 3"cutout, TSP 233/239 .603/600 112 LSA, PRC gold spring kit, untuned.
379 RWHP / 352 RWTQ
The A/F was around 13.3-13.4.
My rev limiter was set at 6400 and the power curve was still going up when it hit the limiter. It would have probably rolled 382-383 with the rev limiter set at 6600 or so. The dyno graphs I've seen w/this cam all peaked around 6200-6300 so I thought 6400 would have been ok for the pulls.
Keep in mind this is still with LS1 intake, stock pullies and untuned. Next mods are an ASP pully, LS6 intake and a dyno tune. Should be right around 400-405 rwhp w/those mods I would think.
http://myweb.cableone.net/97bowtie/dynoscan.jpg
Old Feb 17, 2005 | 01:47 PM
Scream's Avatar
MOOBIES Moderator
And this one...
We just finished up another cam only install with the new 233/239 camshaft! This car was in for a oil pump failure & received new rings, bearings, camshaft & tsp true duals
The car has:
233/239 .603/.600 112+2 Camshaft
True Duals
LS6 Intake
Hooker Headers
Lid
Tuning
Stock Heads
http://www.texas-speed.com/images/233239.jpg
Old Feb 17, 2005 | 01:52 PM
Sport Side's Avatar
What did the custom grind from C-motion look like?
The 383 is a LS1 bore & 4'' crank, right?
Old Feb 17, 2005 | 02:03 PM
Sport Side's Avatar
I don't know how much torque bowtie is going to gain with an ls6 & pulley. The torque looks fairly low. The tune could bring him up though. We'll see.
As for the TSP stick done by TSP. Lets face it, when companies dyno their own camshafts the results are always A+ . Not calling b.s., but I'd rather take a look at more independent results.
I had been following this one too. https://ls1tech.com/forums/showthrea...=tsp+233%2F239
Old Feb 17, 2005 | 02:10 PM
Scream's Avatar
MOOBIES Moderator
234/236 .600 112 w/ a 108 CL
and yes, 383 is a 3.905 bore 4.00 stroke
