Update on my plans
#21
MOOBIES Moderator
Originally Posted by SportSide 5.3
I'd use the c-motion custom, before the TSP grind...
I myself wouldn't use cam-motion. I follow another cam-design approach. Follow is the key word there
I see your point, but can you give me an idea of some ranges that you think I should be looking in (i.e. More duration, less lift, etc).
#25
Originally Posted by Scream
If not the 233/239, then what would you recommend?
Its F-in nuts from 3200 to 6500rpms. And with a big stall its scary even to give it half throttle at 20mph. Nice mean lope too, and I am getting about 320 miles per tank around town and a little highway.
LPE cams arent very much either.
#26
MOOBIES Moderator
Originally Posted by 12sec.5.3
Do you know what kind of horsepower rating they give on the flp's? And any idea what makes the level 5 soo much more expensive than the level 4?
All told, I really wish that I'd have stayed w/ a 60-e, but I'm too far into it now to change my mind. I tried selling the 80-e and got no real interest in it.
#27
I would choose 80 over the FLP anyday! Your doing the Transgo kit on the 80 right? Here how I look at it If you do kill a 80 with the Transgo which is very strong but possible you then get the 80 rebuilt and it is a 1000hp tranny and thats it! yeah its heavy and a power robber but you dont have to worry about it -escpecially after its rebuilt! Good to hear you getting back on the truck. Have you started buying parts? You gonna be selling your 224?
#28
Scream,
I'm sure you are well aware of matching things. Combination. Lets think about the motor. Duration is spotted @ certain valve lift. .05, .200, .006 (advertised) exc.
The duration is the amount of time, those valves are staying open.
On a stock headed vehicle, you may tuck 140+* of duration @ .200'' valve lift. Decent sized camshaft. Now, on a vehicle with say AFR225 heads, your combo may need less. The head is flowing so well, that a large duration camshaft is not needed. If you do spot to much duration on any combo, you will shift your desired rpm range where you don't want it.
When you combine that 140* @ .2'' with a LS1 head that flows 120cfm @ .2, this equals a good combo.
When you combine that 140* @ .2'' with a AFR225 head that flows 150cfm @ .2, for a desired rpm range, this could be considered overcammed. Depending on the rest of the lobe of course.
#29
MOOBIES Moderator
Time to bring this one outta the woodworks...just got my bonus yesterday!
So I've been trying to figure out the things I need to read up on to come up with a good combo. Things like static compression ratio vs. dynamic CR, what CR o go with, cam choice, stuff like that. Is there any good online source for some things I should look out for when trying to put together a good combination? I'm trying to learn as I go, but a lot of what I found isn't really explaining any of this stuff in a way that I understand it. Any other things that I should be aware of when considering what all I want to put into the motor?
#30
You have a good cam, now just do the more simple and reliable thing and add a turbo.
One thing i know for sure is a fast N/A truck is cool, but driving it around everywhere can really suck. At F1 dyno we figured 482 at the crank and thats nice and all, but a stock 5.3 with 9psi would beat that and be more reliable and easy daily driver.
I know this goes against all that i normaly say, but i know you love driving your truck and drive it alot.
