Update on lifter noise!!!!!
#31
coil bind. you will not hit a valve with a piston hard enough to bend a pushrod/break a rocker and not bend the valve. they either put the wrong valvesprings on or the cam has more lift than the springs can handle.
#32
id put coil bind as suspect. if a valve hit a piston you would know it cuz the truck would run like **** from a bent valve
hope that helps.
lukn4trbl355
10-21-2015 11:19 PM
dantheman1540
14
09-28-2015 09:22 PM
