up grading engines?
Old Jul 26, 2008 | 07:55 PM
fl29cracker's Avatar
Default up grading engines?
I am starting a 97 chevy 4X4 project with a weak 305 in a couple of months and wondering what engines are compatible with this truck. If i went with a newer motor such as 5.3 or 6.0, how would it effect my computer and could I use the wire harness off a newer truck for this?
Old Jul 26, 2008 | 08:02 PM
InchUp's Avatar
You're looking at a total reconfiguration. In 99 GM changed just about everything as far as the engine and tranny goes, so you are not looking at an easy swap by any means. I found myself in the same boat as you, swapping from a 96 4.3L which is pretty much the same computer and tranny as your 305, and upgraded to the newer Gen III motor of today. It has not been easy one bit. I've run into obstacles with incompatibility issues at every turn of the way.
The easiest way for you would be to find a complete V8/tranny pull out of a newer 99+ truck, van or SUV and have a custom wiring harness made for you.
Old Jul 27, 2008 | 10:10 AM
sonoma43's Avatar
Or just put a nicely built 350 in it. That simplifies alot of things. The cost of everything to upgrade to the 99+, I could justify buying a 99+ truck for the price you will have wrapped up in the conversion. Dont forget how cheap you can pick up trucks these days. especially 8-9 year old trucks....just an idea.
Old Jul 27, 2008 | 01:23 PM
Default Thanks for the help
That sounds good. I am new with the newer trucks all i ever messed with where 87 or older chevys. and last year i had a leaky intake gasket once i replaced that i started getting more confedent with the model and after reading a couple of articles i thought i would look into that option. i think i will stick to finding a good 350 or when i get back from iraq trade my 454 for something good.
Old Jul 27, 2008 | 02:27 PM
L7 Sierra's Avatar
I believe Painless wiring sells a kit for that application.
I was part of a swap into a late 70's Malibu, and we used that kit which saved alot of time trying to mod the harness.
Oobray
Jun 13, 2022 03:38 AM
ullose272
Aug 5, 2016 02:05 PM
2500ZL1
Jan 25, 2016 06:30 AM
Dirtywhite
Aug 5, 2015 04:10 PM
hackrst
Jul 11, 2015 11:17 AM
