Underbody pics of true dual exhaust setup
Old Jul 28, 2005 | 11:59 PM
SSlow 4.8's Avatar
Default Underbody pics of true dual exhaust setup
My exhaust guy says he wants to see some pics and maybe some suggestions or a list of parts to create a true duals set up on my truck. Its an 01 rcsb 2wd silverado. He said that the gas tank would create a problem... i didnt think it was a big deal to run true duals... to make it easier i was going to have him cut off the cats, but i think im going to run some magnaflow cats... bc he says he doesnt like messing with any emissions stuff (since its unlawful and all )
so heres my plan. Long tubes, to two high-flow cats, to two single chamber mufflers, than either turn downs or out the side before the rear tire.
And the mufflers are 3" inlet/outlet... he said i would probably be better off with the y-pipe that is made for my truck and those headers and just run one of the mufflers.. but i really would like to see if a true dual setup is what its cracked up to be... i was thinking that maybe the use of an x-pipe would help some...
if anyone has any pics, it would be greatly appreciated.
TIA,
Joe.
Old Jul 29, 2005 | 12:17 AM
02sierraz71_5.3's Avatar
I would get a new exhaust guy go to the next county with little emmisions.
Old Jul 29, 2005 | 12:30 AM
ap2002's Avatar
i have heard that stock cats flow as good as the high flow cats from magnaflow???? dont know if this is true... but yeah I would go to a different exhaust guy for sure...
Old Jul 29, 2005 | 12:44 AM
PappyDan's Avatar
Tribe Shaman
ok i will get some battries for the camra and see if i can get some good pics of the pipes for you
Old Jul 29, 2005 | 06:35 AM
Kano's Avatar
this might help
this is 2 1/2"
Old Jul 29, 2005 | 09:17 AM
Scrapin'4.8's Avatar
if u decide to go w/an x-pipe, get turn downs, or at least don't have a lot of pipe after the muffler. If you have a lot of pipe after the muffler, it sometimes tends to cackle (sp) during a certain RPM, this might not be true for all, but it has been w/me. so i'd say either turn downs or before the tire exit. But i say the hell with the cats, get some O2 sims and be done w/it. If ur worried about it being illegal or whatever, just get them to run pipe through the gutted cat.
Old Jul 29, 2005 | 12:12 PM
duwem's Avatar
nice car lift, you konw those blocks can colapse when you put that much weight on them right?
Old Jul 29, 2005 | 12:30 PM
Leroy_454's Avatar
It looks like he also has other jack stands in place.
Old Jul 29, 2005 | 04:32 PM
NeverSatisfied02's Avatar
I would get another exhaust guy! I have also heard that the stock cats flow just as good as the high flow cats. It would be a waste of money to buy the new highflows when you wont even gain anything from them. Just get rid of your cats all together! You will be so much happier. I promise. I did the legal thing and didnt get what i was looking for until i finally had my cats cut off and straight pipe welded in its place. I hope this helps you with your decision.
Ill pst pics of my true dual system when i get back in town.
Old Jul 29, 2005 | 06:48 PM
Kano's Avatar
4 jack lifts
4 8" cmu's
looks safe to me
