under drive pulleys
Old Dec 14, 2005 | 12:12 AM
  #21
URLIFEWASOC's Avatar
What Mods Would Those Be? 2002 4.8l
Old Dec 14, 2005 | 01:08 AM
  #22
Bad_Apple's Avatar
I would suggest....
Nelson Tune
Pacesetter L/T's
E-Fans
Pulleys
then stall
Old Dec 14, 2005 | 01:48 PM
  #23
02gmcwaldoch's Avatar
Originally Posted by speed01rcr
180 is supposedly the optimal operating temp and wear temp.
Not to butt in on the pulley thread but,
Are you saying a 160* thermostat is bad????
Old Dec 14, 2005 | 02:08 PM
  #24
speed01rcr's Avatar
I'm going on a memory in aviation school when we had a conversation about metal wear and operating temp in a recep engine. In these engines, it may also play a factor of how the engine uses timing with the pcm.
Old Dec 14, 2005 | 10:42 PM
  #25
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Called around to ask about pulleys. Futral sells underdrive pulleys for $219 (4.8, 5.3, 6.0) motors. I was told that alt pulleys are a waste, due to slowing the generator down, resulting in low volts. You can run the UD pulleys w/o the alt pulley.
That's what I plan to do.
thunder550
Oct 8, 2015 04:53 PM
chevysten
Aug 13, 2015 07:36 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
bigsapper
Jul 28, 2015 12:56 AM
