under drive pulleys
Old Dec 9, 2005 | 04:05 PM
speed01rcr's Avatar
Originally Posted by TN_TRITON
I think there is better mods for the money
I agree, I had them on a 305 camaro, and an LT1. They were a good concept if free, but I wouldn't pay for them ever again. Ie, there are better things to spend money on.
Old Dec 9, 2005 | 04:43 PM
URLIFEWASOC's Avatar
well alot of things i get at cost or way below retail. Its a 2002 chevy silverad 4.8L so far I have JBA spark plug wires, tr55 plugs, jet chip, k&n intake, replacing the 180 hypertech thermostate with the 160, flowmaster exhaust. What else could i upgrade that would be well worth the money? thanks David
Old Dec 9, 2005 | 06:00 PM
Scrapin'4.8's Avatar
how'd you like the jet chip? i had one in a cherokee and if freaking sucked, caused a major decrease in the gas mileage, actually got down to getting like 9...it sucked.
Old Dec 9, 2005 | 06:16 PM
PEDRO's Avatar
12 Second SUV Club
headers
Old Dec 9, 2005 | 09:21 PM
speed01rcr's Avatar
A good tune and elec fans over pulleys, then do a throttle body port job from mark shaner or someone. Thunder racing does a great mail tune for our trucks and gives great service and support for about $150. He also offers free updates if you need them.
Any tinkering (except normal maintenance) with the ignition system on a naturally asperated LS based engine is a total waste of money. More juice through the electrodes on the plugs is only needed and worth it when it's in a high compression environment, since the air acts as an insulator. (I used to run aircraft plugs through testers alot)
Another thing about plugs that is raping the population, (and I think a law suit should be brought up) is that no matter how many electrodes there are, the arc only uses ONE at a time. This goes back to the WWII aviation spark plugs that first used this design. It was implemented incase one of the ground electrodes broke off in flight. That way they still had an operational cylinder... The EL cheapo plugs work just as good.
sweeeeet
Old Dec 10, 2005 | 01:04 PM
speed01rcr's Avatar
Another thing about pulleys I forgot, on my LT1 I had, I had pulleys on it, and while sitting in traffic with the electric fans running, the volts got so low the car stopped. I also think a constant drain on the battery here along with low voltage to the computer can hurt the curcuitry inside. If you are wanting the most at the track, just pull the belt off for the run, then slip it back on after.
After that happened, I thought "I paid a lot of money for this F$%k up."
Old Dec 10, 2005 | 01:30 PM
What Mods Would Be Good? I Already Have A K&n, Ehxaust, Plugs, Wires, Chip, Thermostat 180 Changing To 160.? What Do You Recommend?
Old Dec 10, 2005 | 01:36 PM
DONT REALLY CARE FOR IT!! Noticed some differents very little. I am looking to sell it.
Old Dec 10, 2005 | 08:28 PM
speed01rcr's Avatar
180 is supposedly the optimal operating temp and wear temp.
Old Dec 10, 2005 | 09:02 PM
litreddevil's Avatar
Banned
i like the undrive pulleys i would get it for all vehicles when an if i can.i am looking for one for my hoe.
