Uncoated pacesetter pics
Old Feb 24, 2009 | 03:01 PM
brent5631's Avatar
Default Uncoated pacesetter pics
I would like to see pictures of uncoated pacesetters after a while of being installed. I'm debating sending mine to jet hot after i'm done welding on them. The only reason i didn't order the coated in the first place was i didn't want to grind and weld on my freshly coated headers.
So post up if you have pics of uncoated headers.
Thanks
Old Feb 24, 2009 | 03:50 PM
andrew383's Avatar
traveling mod
there gonna look rusty....lol.look at your brake rotor's after you go to the car wash.
Old Feb 24, 2009 | 04:14 PM
brent5631's Avatar
what i'm worried about the most is the paint. Does it just flake off?
Old Feb 24, 2009 | 04:38 PM
Tootall's Avatar
it mostly burns off
Old Feb 24, 2009 | 04:44 PM
chevyguy7802's Avatar
Here's mine on my 78' I plan on gettin em coated sometime!
Old Feb 24, 2009 | 04:58 PM
brent5631's Avatar
They don't look too bad.
Where are you getting them coated at?
anywhere semi-local?
Old Feb 24, 2009 | 05:13 PM
outlawz2004's Avatar
I will get pics of mine. I put them on a year and three months ago. The initial paint they came with burned off in ten minutes. I used a spray can of high temp black on them the first day, and I just touched up a couple spots the other day. The only spots that the paint was worn was the collector part under the truck. The high temp paint works pretty good, but I wish I would have paid the little extra and got the coated ones. If you have the funds, I would get them coated, they look better IMO. Mine havent rusted and I drive the truck just about everyday rain or shine.
Old Feb 24, 2009 | 06:08 PM
1989k1500's Avatar
I was kind of thinking about getting painted ones to weld v bands onto the headers and y and weld the y together and then have it all coated but Id have a **** ton into them by then I think.
Old Feb 24, 2009 | 09:28 PM
budhayes3's Avatar
PT's Slowest Truck
I'd recommend getting them coated for a number of reasons...besides warding off rust, the coating will help keep heat in which will aid in O2 sensor performance and lessen the chances of getting a check engine light from "O2 heater performance insufficient". It will also help keep underhood temps lower.
Old Feb 24, 2009 | 09:31 PM
Derek @ EDO's Avatar
FormerVendor
Id recommend just going with the LPP's better design and cheaper than buying the mild steel ones and having them coated.. Plus the LPP's are stainless.
