Ugraded Transmission
Old Feb 29, 2004 | 08:28 AM
If you've really got 600rwhp a built 4L60E WON'T holdup to it,you'll need at least a 4L80E built with high performance clutches and a shift kit.Summitracing carries Hughes and TCI transmissions at a discounted price or FLP can build a 4L80E capable of handling 1200hp if you have the money.You'll need to modify your crossmember,you'll need a different converter,you'll also need a conversion harness and PCM programing from Speartech,a different flywheel,a position indicator switch with bracket,a TH400 driveshaft yoke and a different transmission mount.You're probably talking $5000 or more if you have the work done at a shop.
Old Feb 29, 2004 | 02:30 PM
Texan4Life's Avatar
well my setup as is will most likely be in the 400-415 rwhp range, but as i drive that i was gonna build up a tranny and replace it, and after replacing it, up the power on the truck to 500-520 rwhp and just want to make sure i have something that can handle it
Old Feb 29, 2004 | 09:49 PM
Texan4Life's Avatar
i was talking to a board member and he mentioned these different upgrade packages from http://www.kdsperformance.com/4l60e4.html what of these kits would handle those kinds of numbers?
Old Feb 29, 2004 | 10:02 PM
The one called TorquEnstein will hold up to what you have now,but won't hold up to a max effort supercharged truck for very long.That is assuming everything is properly installed.
Old Feb 29, 2004 | 10:28 PM
Texan4Life's Avatar
will the mega hoss with kevlar band not even do that much? how long would it extend the life, keep in mind i am not hard on the truck, just a few races here and there
Old Feb 29, 2004 | 10:48 PM
I've broken every broken almost every high performance part listed on that site with a 449rwhp Tahoe.I've broken a hardened input shaft,both front and rear 5 pinion planetaries,a 29 element sprag and a reinforced drum,6 "built"4L60Es in all,now I have a 4L80E.All 6 of the transmissions I broke had at least what the site called the TorquEnstein parts installed.
Old Feb 29, 2004 | 10:57 PM
Texan4Life's Avatar
well with the tahoe u have more hp and more weight than i do, but how long did it take you to bust all these parts and are u like a pedal to the metal 24/7 driver or would just every time u mash the gas it broke or what?? thats nuts!
Old Feb 29, 2004 | 11:24 PM
The 1st and 2nd transmission fried the clutch packs because of defective TCI torque converters. The 3rd transmission smashed a rear planetary at the track after a hard launch,when it made the 1st to 2nd gear shift,that one got me home.The 4th transmission smashed a front planetary street racing when I hit 3rd so I just lifted I limped home in 2nd gear.The 5th transmission broke at the track when a spider gear broke in my Auburn Pro and took out the rear planetary and a 29 element sprag.The 6th just quit running down the interstate highway 400 miles from home when the 13 vane pump failed.When I got the truck home I was on the phone buying a 4L80E.
Old Mar 1, 2004 | 09:29 PM
Texan4Life's Avatar
thats nuts
Old Mar 2, 2004 | 09:12 PM
Texan4Life's Avatar
anyone else had any other problems?
