U-Joint Question
Old Dec 15, 2003 | 11:46 PM
Phatchevy's Avatar
Default U-Joint Question
my roomate has a 2000 z71 w/ 6" lift, 3" body lift, and 36" tires. there is a loud squeaking noise coming from under the truck that gets louder as the truck goes faster, and it's not the tires/brakes. there is also a clunking sound when he puts it into drive or reverse. some off-road guys up here think it is the U-Joint. anyways has anyone had a similar problem? so is it the u-joint? if so how do you fix it? and what tools would be needed?
we were thinking about taking it to the dealership but didn't know if it would be covered under warranty. he also has an extended warranty so hopefully you all could let us know.
Old Dec 16, 2003 | 05:55 AM
mudz5.3's Avatar
There is an update that gm is doing on our trucks. It is a nickel plated slip yoke. I had the same noise coming from mine and they replaced it. The squeaking is probably the u joints and I am not sure that would be covered under warranty with the lift. The slip yoke should be no matter what.
Old Dec 16, 2003 | 06:33 AM
onyx's Avatar
14 Second Truck Club
if its the slip yoke, good luck trying to get a dealer to help.... all the ones down here just blow me off... i'm about to put a boot in their ***... my truck makes the noise when put into gear also...
JordanH
Dec 25, 2015 08:32 AM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
iregret
Sep 7, 2015 01:20 PM
