Tweaking the intake?
Old Oct 22, 2004 | 02:27 PM
derek_silvy's Avatar
Default Tweaking the intake?
I've got the K&N FIPK and I'm going to the track tonight and want to do a little tweaking.
This post concerns the intake setup.
Some say taking the passenger headlight out helps it get a more direct shot of air. Is this true? Does it even make sense in theory?
Also, I am sure that many of you with the FIPK have noticed that the intake tube lays on top of the hot upper radiator hose, therefore heating (to what extent, I don't know) the air charge. Has anyone tried to address this problem? How? What was the outcome?
Old Oct 22, 2004 | 03:08 PM
Once underway, the intake charge cools to ambient in a matter of seconds. Do not bother trying to anything unless you are unemplyed and have lots of time on your hands.
Old Oct 22, 2004 | 04:18 PM
v8
17,16,15,14,13,12,11 Drvr
removing the head light just lets the cooler air come to the filter faster , i have removed the filter and ran it with the filter on both times the same so the filter is doing its job. on the tube i used insulation rated at 1600 degrees F, does it help probly not but wtf huh lol later, kevin
Old Oct 22, 2004 | 04:24 PM
Scream's Avatar
MOOBIES Moderator
I always run with the headlight out.
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
