cam install help
Old Oct 18, 2004 | 07:27 PM
Kano's Avatar
Default cam install help
gettin ready to put the cam in
got a few ?'s
1 whats the thread size of the rocker arm bolt?
2 what size is the spark plug 14mm or 18mm?
3 what gaskets do I need and what can I reuse?
4 any tips
Old Oct 20, 2004 | 08:28 PM
eallanboggs's Avatar
If your careful you can reuse the water pump gasket and timing cover gasket, but examine them closely before reuse. I would repalce the pulley seal. The plugs are 14mm. I'd install a double Rollmaster and ported pump while your at it. These items aren't too expensive and your reliability will increase along with your oil pressure. It sounds oxymoronic to skimp on gaskets if your going to buy an aftermarket timing set and oil pump, but my gaskets were in such good condition I didn't hesitate to reuse them even though I had a complete new gasket set on hand. Those new gaskets are still setting on the shelf for the next tear down which hopefully won't be for a long time. Use plenty of assembly lube or oil as you put everything back together. If you do install a double row timing set I can give you some tips on how to get the oil pump pickup tube bolt back in. That can be very tricky because of the 3mm spacers required with the double row timing set.
Old Oct 20, 2004 | 09:00 PM
one03sierra's Avatar
Formerly one92rs
Talking
what cam was this. how big. are you installing springs? water pump-timing cover-front seal.i have reused all gaskets on installs but i dont like to.
Old Oct 21, 2004 | 03:13 PM
Kano's Avatar
thanks I'll order a set from SDPC just in case
Its a Vinci 062 210/218 112 .551
I have comp 918's
yall know the rocker bolt size
Im making a tool
Old Oct 21, 2004 | 03:24 PM
Flyer's Avatar
8 mil with a shoulder
I wouldn't worry with the gaskets. Just don't yank on them and they will be fine.
bourbeaugmcx's Avatar
tell me how that cam idles when you get it in. i want to by a choppy cam, but been told that my truck can't run a coppy cam. what rpm your idling at
Old Oct 21, 2004 | 03:26 PM
Flyer's Avatar
LOL ... if a 4.8 can't run a choppy cam, I wonder what you would call 01Thunder's cam.
Old Oct 21, 2004 | 03:47 PM
All the tech at these companys tell me its not a good idea.i'm confused!!
Old Oct 21, 2004 | 03:52 PM
derek_silvy's Avatar
Tuned right it can run a choppy cam...
Talk to a tuner who knows what he's saying.
-Derek
Old Oct 22, 2004 | 05:02 PM
My truck with 4.8 has a choppy lope. It has a 112 LSA and I gutted my cats. With headers and a dual cat-back it sounds mean, but it is quiet at idle although yoiu can hear the lope.
all_individual
Oct 10, 2015 10:09 PM
low2001gmc
Jul 23, 2015 05:10 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
ssierra08
Jul 15, 2015 06:40 AM
all_individual
Jul 13, 2015 11:01 AM
