TVS 1900 coolant port AN?
Old Nov 29, 2019 | 09:56 AM
dantheman1540's Avatar
Default TVS 1900 coolant port AN?
I plan to redo all my coolant lines for my TVS1900 In -12 nylon braided AN lines and fittings just to clean stuff up. One thing I cannot seem to find is a different port for the back of the Maggie. I know I could buy weld on fittings but I'd much rather unbolt this port and bolt on an AN port.
Anyone already have a solution to this problem?
Old Nov 29, 2019 | 11:42 AM
03sierraslt's Avatar
Not that I ever found. I looked years ago.
Old Nov 29, 2019 | 01:50 PM
Well that's lame. I really hate hose clamps
Old Nov 29, 2019 | 02:55 PM
me too! When I pulled those hoses off I found it the easiest to just remove the bolt and the whole cooler block as one with the lines attached.
Old Nov 29, 2019 | 06:15 PM
That is a good idea. Honestly when I first slapped everything together I didn't even realize it was a one bolt removal.
Old Nov 29, 2019 | 08:43 PM
arthursc2's Avatar
I'd be happy to weld some bungs on that for you, let me know if you'd like to do that 🤘🏻
Old Dec 1, 2019 | 08:38 AM
1994Vmax's Avatar
Otiker clamps work fine as well on the nipples they have existing.
Old Dec 1, 2019 | 03:53 PM
I bought all braided nylon -12 hose and that stuff frays so bad when cut. I would be eternally mad at myself for using hose clamps and making it worse. Arthur has graciously offered to weld some bungs on for a good price so this piece will be in the way to his house soon.
Old Dec 2, 2019 | 11:50 AM
Nice. So if you look at the intercooler core after you remove the coolant manifold you will see how restrictive the ports are. Kind of a joke. I opened mine up and got a lot more flow.
Old Dec 2, 2019 | 04:53 PM
How did you port them? Just Dremel and rotary file bits? I've never ported anything before but I plan to port match my header flange a little better and I have plenty of rotary files.
