Turning E-fan On Help!!!!
Old May 18, 2005 | 09:52 PM
desTRUCKtive's Avatar
Set the temps lower while your checking so you don't have to wait for the truck to warm up as long. If the harness is working then set them up like Allen mentioned. Just a tip.
This is what we did at the begining, we set the temps to 160 just to see if they would go on. But nothing happened.
I guess all that is left is that connection.
Old May 19, 2005 | 01:58 AM
thunder550's Avatar
High on diesel fumes
Yep! It was the pin. I didn't have it in far enough....I still couldn't get it all the way down but I got it in far enough to make contact, so the fans run ok. I'll have to take it apart again later to seat the pin all the way, but I ran out of patience. Sweeeeeeeeeeeeeet
Old May 19, 2005 | 08:49 AM
sweet so the fans are turning off and on. Let me know if you need to adjust the temps.
Old May 19, 2005 | 07:06 PM
thunder550's Avatar
Yep the fans are working!!! I'll give it a little bit and see how the fans are doing, running all the time / etc...maybe later I will have you adjust them, but I think they should be fine for now. We were pretty close to the numbers Allen recommended.
Old May 19, 2005 | 07:31 PM
KySilverado's Avatar
For what it is worth. Stock Fan settings 05 Truck
Fans Stage 1
on 226
off 219
Fans Stage2 (which we dont have)
on 235
off 227
Engine off
Disable 250
time 1
Old May 20, 2005 | 02:04 AM
thunder550's Avatar
Those temps seem really high
dsbodley
Nov 14, 2015 09:46 PM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
