Update on my truck
Old May 19, 2005 | 10:26 AM
ranwalk's Avatar
Talking Update on my truck
Heard back from Allan at Futral. Things are looking good. I dont have any specs just yet on cam and such but here is a break down of what it will consist of when done. Engine of course being built by Futral
still a 6.0 liter
diamond pistons
stock rods
stock crank
ARP head studs,main studs,rod bolts
ported oil pump
rollmaster double timing chain
new cam-custom from Futral-(dont know specs yet)
slight head work-bigger valves,valve job,blend seats
Comp 918 springs
Thunder racing pushrods
comp lifters
all new bearings
160 t-stat
Whipple supercharger
Looking into changing up exhaust-Pacesetter long tubes,3inch y going to a 3 1/2 inch single.
Electric fans
34 inch core radiator
Yank TT300 converter
4.10 gears
Eaton posi
K&N FIPK
42 pound/hr injectors
I think thats it for now. Yall think this will end up making a good combo?
I hope so. I know this, I need some good luck to come my way, I just realized this will make engine #4 in just 2 years
Old May 19, 2005 | 10:29 AM
Wilde Racing's Avatar
How do I change this text
sounds good, how much did all that set you back?
Old May 19, 2005 | 10:42 AM
ranwalk's Avatar
I'm afraid to total it all up
Alot of it has been done for a while over the last 2 years.
The biggest change will be the engine and changing exhaust.
Old May 19, 2005 | 11:55 AM
Scream's Avatar
MOOBIES Moderator
Sounds good...get that thing running so you'll come around here more often!
Old May 19, 2005 | 12:20 PM
redaddiction's Avatar
Looks good to me I'm on my 4th engine also so don't worry you aren't the only one.
Old May 19, 2005 | 12:25 PM
Sport Side's Avatar
Is your truck mainly for the strip or street/strip? What sorta 1/4 mi. times are you shooting for with this new setup underway?
Old May 19, 2005 | 01:20 PM
ranwalk's Avatar
This is actually my daily driver if it will stay together long enough
Once I get it paid for it will become more of a toy though, but will allways be a street /strip vehicle. As far as 1/4 mile predictions, I dont know. Once it's all together and I get some dyno #s i'll
have a better idea of what it should do
Old May 19, 2005 | 03:29 PM
12sec.5.3's Avatar
Sounds like you'll have a great combo. I talked to Allen today also about my new setup. He's gonna take care of you. What compression will the new motor have?
Old May 19, 2005 | 03:33 PM
ranwalk's Avatar
Not sure about the compression, I'm just gonna leave it in his hands. Whatever he says goes
Old May 19, 2005 | 03:44 PM
GenIII53's Avatar
My .02......with all that money tied up in your combo, I would not have gone back with stock rods, especially since the motor is aprt and all. Why even risk it?
