turbo or supercharger?
Not in a bad mood, You keep asking the same question and I keep answering it. The Heat Exchanger is just fine
One can always benefit from more surface area to catch air to cool the water with. But there comes a point where it will take longer too cool than it is worth, hence the answer the Heat Exchanger the Radix comes with is fine.
Ok understood. I just assumed there was a limit to it's cooling potential. Like how Parish upgraded his H/E and I could have sworn a couple other guys with a Radix did theirs also so I thought that there was a point were it was required to do so.
Sorry for the repetativeness.
Originally Posted by F8L Z71
I'd have to lean towards the Radix for your needs. i think you'd be happiest with it. You will want to get a good trans cooler and keep an eye on IATs. Under heavy duty towing you may have to look into a better heat exchanger. The Radish guys could give ya more info on that though.
btw...like your race videos
wrb002
Aug 25, 2015 03:56 PM
