turbo setup
Old Dec 14, 2008 | 02:04 PM
Go5.3tt06's Avatar
Originally Posted by kbracing96
You can make good power out of a ZO6 cam only, 4.8 and an intercooled turbo, look at my numbers, that and meth is pretty much what I have. Well actually, I have the Vinci Ultra torque can, which is very similar to the Z06 cam. Those numbers where at 11-12psi of boost
Are you running 112 or 114 lsa what size cam from Vinci you have on it?
Old Dec 15, 2008 | 01:09 AM
kbracing96's Avatar
It's the Vinci "ultra torque" 210/218, .551 i/e, 116lsa I believe.
Old Dec 15, 2008 | 01:27 AM
Thechevyman122's Avatar
everyone bashes the 4.8..but people dont remember that the current 4.8 has more power than the 5.3 did untill 2006 i believe...and that the early model 6.0's '(untill 02 i believe) were rated at 300hp, and now the 4.8 is rated at 295.
If it was me i would stick with the 4.8 and turbo the hell out of, be different and spank all those bolt on packed 6.0's. Good luck man, and keep us posted
that is ofcourse if you have a "new 4.8" if your new truck is just new to you and its the truck in your sig, i would look at doing a low mileage swap..being an 02 it no doubt is starting to accumulate some miles too.
Old Dec 15, 2008 | 08:11 AM
BlackGMC's Avatar
Resident Retard
My 4.8 does pretty well for what it is... I keep up with most of the 5.3 guys at my local track and they have comparable mods..
Old Dec 15, 2008 | 08:16 AM
GMCtrk's Avatar
Peak power means nothing. It's all about under the curve power.
Old Dec 15, 2008 | 08:18 AM
nonnieselman's Avatar
Originally Posted by silveradokidd_4518
i looked up the specs on the Z06 cam (205/219 .551/.549 117 LSA) << and someone please correct me if i am wrong on those specs but i was kinda looking for something a little bit bigger in size of the cam if it will be a good idea. something more like a 212/212 .558/558 113 LSA ?? im not sure though...
Corvette Cam
02-04 12565308 204/218 .555/.551 117.5 405hp
Just start out with a turbo and go slow from there..
75 shot plus boost is alot!!
Here is what mine did just to give you an idea..
13.2@104 on 5#
12.5@111 on 5# and 50 shot.
50 shot dropped me 7 tenths and gained 7mph..
So if you do decide to spray, start low around 35 and you will learn.
Old Dec 15, 2008 | 08:21 AM
GMCtrk's Avatar
Corvette Cam
13.2@104 on 5#
What kind of kit and electronics do you use for the nitrous?
Old Dec 15, 2008 | 08:23 AM
peice together kit through a early Nitrous outlet TB spacer and just a Arming switch and WOT switch.. Spraying it at the green light.
Ill be getting the MicroEdge from HSW here shortly.
mhorn0817
Jul 8, 2017 01:54 AM
iregret
Jul 27, 2015 10:32 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
oharajo
Jul 18, 2015 09:24 PM
