turbo question
Old Dec 21, 2004 | 09:49 PM
jow02327's Avatar
Default turbo question
Would twin T3/T4 garett turbos be a good setup..... as far as quality and power??? (Or even just one?)
Old Dec 22, 2004 | 12:35 AM
Green Thunder's Avatar
You will need two.... What other mods do you have?
[IMG]
Old Dec 22, 2004 | 10:49 AM
jow02327's Avatar
pretty muck stock. if i decised to fabricate a twin kit i would upgrade injectors ,fuel pump, cam. did you fab your own kit?
Old Dec 22, 2004 | 06:49 PM
fullthrottledan's Avatar
yeah, you will max out one of those turbos in a heartbeat. 2 is nice...trust me.
Old Dec 22, 2004 | 10:05 PM
Yeah
What size exhaust housings are you running?
What other mods have you done FTD?
Old Dec 22, 2004 | 11:59 PM
they are 1.15 exhaust. i thought they would be to laggy, but they are no that bad at all. hks 50mm gates and hks blow off valve. little cam(hehehe) and ls1 heads which i flow benched and ported at school. I used these heads to lower the compression ratio a bit other things here and there but you get the point.. also running a 75 shot off the line.
Old Dec 23, 2004 | 12:06 AM
1.15's? Where does your boost start? Approx RPM's?
Old Dec 23, 2004 | 12:07 AM
i can stall the truck (stock stall......) at 1600 and get 2psi out of it, but it doesnt take long to get to 12psi, maybe 3200 i think. right in that area. if i could do it agian, i wouldnt run a 1.15 on the street. id go smaller. they are nice at the track(street tested, track is closed) because i use nitrous to make up for the lack of boost.
Old Dec 23, 2004 | 11:43 PM
man how many hp you making you got one sweet setup.
Old Dec 24, 2004 | 12:24 AM
no idea. i need to find out though
