Turbo installation questions
Old Jun 23, 2005 | 06:12 PM
Scott Mills's Avatar
Default Turbo installation questions
Do anyone have the installation instructions for their STS turbo that they can email to me? I need to know where to hook up the oil supply line and where to wire the oil pump up to?
Old Jun 24, 2005 | 11:30 AM
TG02Z71's Avatar
Here it is, mine is a 4x4 so the driveshaft is close.
The blue thing is the oil filter!
Old Jun 24, 2005 | 12:46 PM
Thanks for the picture. Is the MAF positioned in the intake pipe that runs from the turbo?
Old Jun 24, 2005 | 01:02 PM
TG02Z71's Avatar
It will be close to your exhaust on your passenger side, you may need some type of heat blanket to keep your maf cooler. The wrap really helped allot, only wish i'd bought a wider peice to go over the whole MAF! The stuff is not cheap.
Old Jun 24, 2005 | 01:06 PM
JERRY2500's Avatar
14 Second Truck Club
PM you
Old Jun 24, 2005 | 05:44 PM
Has anyone tried an external oil tank for the turbo? It seems like it would be better than drilling into my motor.
Old Jun 25, 2005 | 12:51 AM
kbracing96's Avatar
FWIW mine is also a 4 wheel drive and I installed the little block that the oil fiting screws into pointing up and then ran the oil line over the top of the trans. worked out great and is no where near the front driveshaft. But I think Scotts being a 2500 probably has the oil cooler on it and that is more dificalt to drill out and tap that block if I remeber right from when Mort did his.
Also, the oil pump relay wire should tap into the gray fuel pump wire coming out of the side of the fuse box on the drivers side of the engine compartment.
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
lxcoupe
Jul 21, 2015 02:12 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
