turbo cam ??'s
Old Jun 24, 2005 | 04:50 PM
  #51
Sport Side's Avatar
Originally Posted by 4.8T
This cam will have a little lope. If you use stock rocker 1.7 then your lift will be 547 intake and 545 exhaust and you can use stock LS6 springs. If you go with the 1.8 rockers you will need to upgrade the springs. Thank you
got this today from cammotion why can't they gimmie the 1.8 grind in the 1.7 form like .579(1.7)/.577(1.7) instead of .579(1.8)/.577(1.8)
On a forced induction motor, the intake lobe doesn't need such an aggressive ramp rate. Natural induction motors use faster ramps to help pop the valve open quicker, where the head flow is higher. When the intake is under pressure, a slower lobe can be used.
However, I don't know if this applies to your setup.
Old Jun 25, 2005 | 05:25 AM
  #52
TURBHOE's Avatar
this is the other they said but i'd have to upgrade my springs
The closest thing we can do would be:
Grind # X2161-2081-15+3
Dur @ .050 218 intake and 214 exhaust
Lift 564 intake and 545 exhaust (1.7rr)
Lobe separation 115
Intake centerline 112
This would give you more lift on the intake and that is what matters. You
Old Jun 25, 2005 | 05:40 AM
  #53
Mr. Sandog's Avatar
So you're giving up a degree of intake duration (218 vs. 219) in exchange for .017" of additional lift (.564 vs .547). That's basically your decision.
Regardless, I think you'd be fine with the LS6 springs with either cam.
Old Jun 25, 2005 | 11:07 AM
  #54
TURBHOE's Avatar
so which one sounds good?
Old Jun 25, 2005 | 04:44 PM
  #55
Mr. Sandog's Avatar
I think either cam would be great, and there would be so little difference between the two that you would never notice. It's your call.
Old Jun 25, 2005 | 05:07 PM
  #56
TURBHOE's Avatar
damn the more i shrink down the amount of choices the more i get what is up with that. ok i'll close my eyes and pic i guess ****. it will be a little while anyway but at least i got thwe searching out of the way so when time comes i know where to buy.
greedygenius
Sep 3, 2015 06:51 AM
lxcoupe
Jul 27, 2015 08:19 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
black6spdz
Jul 16, 2015 01:32 AM
Atomic
Jul 11, 2015 03:51 PM
