Turbo and cam questions
Planning on the truck. Its tax season
I know what the search button is, but last time I checked, I didnt find anything.
The plan for my truck is a Twin Turbo on the 5.3 with a tiny bit of boost (~5lbs), Trailblazer I6 converter, custom ground turbo cam, heads, and exhaust.
I want a really fast spool time, so I was figuring on using two 47mm turbos, but need to know about hot and cold side sizing. Stall will be about 2600, so 2500-2750 is optimal for boost to set in, to me. Are these turbos too small? I dont need to rebuild Parish's truck, I just want a nice addition to mine.
Im planning on running a 207/204, .555/.555 116 or 118lsa cam, so I still have a little low end grunt, but it doesnt bleed off boost.
The exhaust would be a custom fab job by me. 3" downpipes merged into a 4" single, out the back corner with a 4-5" tip.
Ported/Polished 5.3 Heads are what is going to be on it, maybe even a ported intake.
I dont want driveline snapping power, but I dont want the lag of a medium sized single turbo. I cruise normally right under 2k, so it will keep me out of boost while cruising too.
any help is appreciated. THanks!
Why would you want to speed that much money on a project to only run 5 psi of boost? A single T60 with a .68 A/R turbine in a front mount set would give your the near instant boost you are looking for. It was almost Radix like boost on my 4.8.
So, a single t60 is just as good?
I want the option of building the hell out of it down the road a little bit, which was why I wanted twins.
Im trying to stay out of boost while cruising, but yet be able to have instant boost once i touch the gas.
I am set on Turbo (s), I like the sound better, and I can honestly do it cheaper than a maggie or any other s/c.
I can do all my own work, Ive got the stuff to do it with is the main reason for wanting to go this route. Im not looking to spend over $2500-3000 by doign it myself.
The only thing I will be getting done elsewhere is a dyno tune.
Also, are the cam specs favorable for what I am wanting, along with the I6 verter?
We'll see, Ill be keeping all my invoices to check. So far, it looks do-able. Especially having friends at any kind of automotive shop in town to do anything I might not be able to do in the garage.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
lxcoupe
Jul 27, 2015 08:19 PM
bbowerman
Jul 26, 2015 10:57 PM
Have you been for a ride in a Maggie truck? Sounds like exactly what you are looking for.
