Turbo boost reference signal location.
Old Mar 28, 2005 | 09:21 AM
TG02Z71's Avatar
Default Turbo boost reference signal location.
Right now I have mine comming from the top of the snail (see pic) , but I have heard fom some on here it better if you get your signal from a point closer to the throttle body. Would it be best before or after the MAF?
Just have to braze a bung on I guess to relocate it.
Attached Thumbnails Turbo boost reference signal location.-dsc01787-small.jpg
Old Mar 28, 2005 | 09:38 AM
bud8fan's Avatar
on the passenger side of your intake near the firewall is a vacum port sticking out and all you have to do is twist the top off it and connect your hose to it...if you have a "t" then you can run to your boost guage as well from the same place...
Old Mar 28, 2005 | 10:01 AM
JERRY2500's Avatar
14 Second Truck Club
Old Mar 28, 2005 | 11:41 AM
kbracing96's Avatar
I asked the same question a couple days ago and got the same answer as you. I emailed TiAl and asked them if it would be ok for the wastegate to see vacuum and got no answer, so I hooked it up just like these guys said and it seems to work just fine.
Old Mar 28, 2005 | 01:27 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I don't think you need to mess with it unless you see spikey boost. I don't and I'm pulling the signal from the snail shell.
Old Mar 28, 2005 | 01:32 PM
JERRY2500's Avatar
Erik, You should try it, It made a big difference in the performance.
Old Mar 28, 2005 | 01:37 PM
bud8fan's Avatar
the only reason we are relocating the line there is we want to see the true boost # at the motor and where else to get that than right on top of the motor at the intake...true boost and vac numbers at the motor...especially if you are fmic with all that xtra pipe and all...and yes you can tell a diffrence when you relocate the line to there...
Old Mar 28, 2005 | 01:56 PM
TG02Z71's Avatar
This is why I asked the question. So there is a difference to where you get the signal from then? I just want to reduce any lag that I get when on and off the throttle and from a stop so it spools up quicker.
GXPJAY
Feb 13, 2022 08:15 AM
Jake99
Aug 8, 2015 07:56 AM
03regcab sierra
20
Aug 3, 2015 12:11 AM
Ketis
Jul 23, 2015 12:37 PM
