Tuning neccessary with .030 milled heads?
Old Jul 27, 2004 | 09:28 PM
Z71/99's Avatar
Default Tuning neccessary with .030 milled heads?
I already have the neslon tune and really need to know if I will have to have my truck re-tuned when i get it running again.
Thanks alot guys! I apreciate yalls help.
Old Jul 27, 2004 | 10:11 PM
greentahoe's Avatar
I would think so. Did you mill to raise compression or get better flowing heads and mill them to regain stock compression??
Old Jul 28, 2004 | 12:23 AM
I would have it re-tuned. That much off can definately cause knock and that is the mother of all engine enemies. Not to mention it is too cheap not to have it done.
Old Jul 28, 2004 | 07:43 AM
A tune is not neccisary, but it does help. If you get low grade gas or bad gas KR will be a bitch though.
Old Jul 28, 2004 | 12:20 PM
Z71/99's Avatar
Thought so. O well I sould have it re-tune anyways w/ headers and exhaust,
thanks again guys yall are a big help with my project.
Old Jul 28, 2004 | 12:50 PM
Where are you getting the heads done? I used to use a machine shop right off I-35 just before Mopac. They do a great job for a low price.
Old Jul 28, 2004 | 02:11 PM
It wouldn't be any problem at all if he was on a stock tune, but he is already on a nelson tune for his lower compression. I would think that it would be very beneficial to get a re-tune.
Old Jul 28, 2004 | 05:06 PM
Z71/99's Avatar
My friend recommended a shop for me in Llano, getting my heads milled and three header bolts that broke off in the head taken out is costing me around $80.00 then the adittional $198.00 for new gaskets and head bolts. The bolts were the only reason I took the heads off in the first place then decided I needed to do something else performance wise while they are off.
I would do some headwork to em' I just dont trust myself.
Thanks again
Old Jul 28, 2004 | 05:41 PM
gonzo 6.2's Avatar
Did you consider the effects of pushrod length?
GrooveCityZ71
Aug 31, 2015 12:05 PM
BennyB
Aug 1, 2015 08:48 AM
steves86ta
Jul 28, 2015 10:21 AM
bobfig
Jul 25, 2015 04:42 PM
4B11T
Jul 13, 2015 03:48 PM
