Tune it up.
Old Apr 8, 2011 | 08:04 PM
youngbuck's Avatar
Default Tune it up.
Had some work done to my truck an now it runs like a , what would cause it? I think the tune got erased, so who should I go with now? It had a street tune an ran great but the tc lockup wouldn't happen till 55, want it to lockup around 45 to help my mpgs some with this stall. So let me kno who u like and why. Truck in sig,Thanks fellas.
Old Apr 8, 2011 | 08:19 PM
SnakeOiler's Avatar
What work did you have done? Who did the work?
Old Apr 8, 2011 | 09:30 PM
youngbuck's Avatar
He disconnected the battery, had to change my ac compressor. Family friend did the work.
Old Apr 9, 2011 | 08:25 AM
andrew383's Avatar
traveling mod
Disconnecting the battery wont "erase" the tune...Maybe talk to your tuner and see about getting a retune..
Old Apr 9, 2011 | 10:18 AM
youngbuck's Avatar
He took the negative off first, I thought that reset the pcm
Old Apr 9, 2011 | 01:11 PM
DV2000NJ's Avatar
13 Second Truck Club
No, you can't erase the tune just by disconnecting the battery.
Old Apr 9, 2011 | 01:28 PM
budhayes3's Avatar
PT's Slowest Truck
Sounds like the pcm just needed to relearn idle, as for the OBDII port, check the fuses as mentioned as this is quite often the case when you don't have communication at the OBDII port.
Old Apr 9, 2011 | 02:53 PM
SnakeOiler's Avatar
All that does is reset the long term fuel trims. No biggie. (Also clears any DTCs)
Old Apr 9, 2011 | 07:25 PM
youngbuck's Avatar
What about the lockup happening at 55? how is everyone elses set like?
Old Apr 10, 2011 | 11:19 AM
fastnblu's Avatar
I thought my lockup was 41, but since I'm gettin terrible MPG, I think I'm gonna change it. And some other things too at least on the tranny side.
Who knows what else, but I need better MPG of out mine, cause it's killin me @ the pump, plus what gas costs too. And my lockup in my particular case, can be an issue in traffic, so I hope to stop it from lockin / unlockin by adjusting as needed.
I planned on doin it today, funny I saw this.
