? Tundra times
Old Jul 1, 2002 | 09:15 PM
Puffnstuff's Avatar
Default Re: ? Tundra times
Just one thing about all this guys, the tundra isn't a full size truck, at least in my mind it isn't. It doesn't have the wind resistance of a full sized front end pushing air out of the way and it's smaller all the way around. Really it should be compared to a dakota since they're about the same size.
Old Jul 1, 2002 | 09:45 PM
CHAGO's Avatar
i disagree puff,
i'd say the s10/sonoma, dakota, tacoma, the little nissan trucks, and the ford rangers are on the same page. noting that the only one with a v8 option is the dakota.
The Tundra looks much bigger than the rest of the little trucks.
I read the tunda is rated at 245 hp / and 3 something torque. it may be designed differently, (aerodynamics) my opinion is as long as you have anything stock height, you will encounter wind resistance.
Old Jul 1, 2002 | 10:37 PM
WidowMaker02's Avatar
The Tundra is slow compaired to the 5.3 chevy.I have raced at least 4 or 5 of them theres no compition;Even with a super charger they will probably only run high 14's or low 15's.I have seen 2 at the track run 16.8,and 17.1 motor trend shows them running a 16.9 1/4 then ad a power adder s\c this would = at the best a high 14, or low 15 second 1/4 if they get traction;That puts them right in the same range as a stock Exc Chevy. So truck for truck the chevy is faster.So smoke that Tundra!
Chevy <img border="0" alt="[Truck]" title="" src="graemlins/gr_truck.gif" /> rules - <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" /> Tundra
The WidowMaker02 <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
<small>[ July 01, 2002, 10:39 PM: Message edited by: WidowMaker02 ]</small>
Old Jul 2, 2002 | 12:31 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
The only time I have seen a Tundra on a track was at Penwell near Odessa TX, I think it was last spring. Anyway I remember him racing against a F150 ext-cab three or four runs and they were both running low-to-mid 17's. <img border="0" alt="[boring]" title="" src="graemlins/gr_zzz.gif" />
Old Jul 2, 2002 | 02:57 PM
Terry Burger's Avatar
My S10 is just as tough as the big 5.3L Chevy trucks.... =) After a few simple bolt on mods it will be quicker too!
Old Jul 2, 2002 | 03:28 PM
Brandon Boomhauer's Avatar
10.80?
youll smoke him
im runnin 10.0s spinnign for ever on 235s
and cant break into 9s...
i think a better set of tires will help that out
and racing before the imports fly through the water box.... <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Old Jul 2, 2002 | 05:28 PM
jcfreak's Avatar
Brandon
Is yours a stock 5.3? If not what have you done to it?
Old Jul 2, 2002 | 05:31 PM
jcfreak's Avatar
Brandon
I used cooper cobra radial gt's on my S10 and they hooked pretty good for a street tire. Just had to find the sweet spot on the rpm to keep them from spinning.
Old Jul 2, 2002 | 05:41 PM
upd intake
3in flow master from just before the flange back 40 series
2in rear drop...
235/75 stock goodyears....
Old Jul 2, 2002 | 06:08 PM
jcfreak's Avatar
So that is what you ran after the mods? Did you do any runs before the mods? Trying to find out how much difference it made on between the two.
