True Dual On A 5.3
Old Nov 26, 2004 | 04:04 PM
Default True Dual On A 5.3
How much difference in sound and performance between a true dual system from cats back or standard cat back system both using magnflow! I did a custom magnflow cat back with 2.5 inlet and dual 2 outlet to dual tail pipes. With the buick being very quiet inside i would like more of the muscle sound. The new system i would do would be magnaflow with dual 2.5 pipes and 2 round mufflers with 2.25 exit's with dual tail pipes and tips. any thoughts? This is a 2004 buick rainier 5.3 LM4 by the way!
Old Nov 26, 2004 | 04:47 PM
TarheelZ's Avatar
I'll offer my opinion on this with the caveat that I'm not an expert on performance and exhaust, so keep that in mind.
I suspect that you'd be most pleased with a single-in/dual out Magnaflow rather than a true dual set-up UNLESS you are planning to get real extreme (power-wise) with the engine in your Buick. The Magnaflow on my truck actually has a single 3" pipe with a 3" exit pipe because I feel I get the best performance with this set-up.
Hopefully, some of our brethren will jump in here with their thoughts and you'll be able to make an educated decision. Good luck!
Old Nov 26, 2004 | 04:55 PM
I must say i'm not expected to gain anymore ponies, but i would like to get a meaner sound! Sound is first on the list. I know i gained a little with the set-up i have now, but not the sound i'm going for.
Old Nov 26, 2004 | 05:11 PM
TarheelZ's Avatar
I'm not sure if this applies to their products for the Ranier, but typically Magnaflow makes a few different mufflers for each system and the shorter the muffler, the more aggressive the sound. If you bought the longest & biggest, it probably produces a more subdued sound. See if they have a shorter model for your vehicle.
Old Nov 26, 2004 | 11:45 PM
Kano's Avatar
since power and performance isnt worried about go with a flowmaster 40 dumped
Itll be loud enough then
Old Nov 27, 2004 | 12:24 AM
14 Second Truck Club
Run a x-pipe, some 2.5" Dynomax Bullet Mufflers and run the out the back. Mine sound awesome, ask my neighbor who doesn't like me!
Raggedz71
Jul 29, 2016 10:20 AM
thewrx
Aug 12, 2015 08:28 PM
Zack R
Aug 3, 2015 06:02 PM
vmaxpro
Jul 27, 2015 10:45 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
