Truck wont start, help
Old May 13, 2014 | 09:02 PM
00blackz71's Avatar
Default Truck wont start, help
Got an 03 GMC sierra that will spin over but wont start. Only code showing was a security code for no fuel P1626. I disabled the vats through hptuners and still wont start. It has 55-60psi while cranking and has spark at the plugs(only checked 3 plugs). Plug fires at the same time as compression hits. Wont hit a lick on starting fluid. With a test light the injectors show to be firing. Any ideas what to do next?
Old May 13, 2014 | 09:09 PM
trxmxzx's Avatar
13 Second Truck Club
I think on a thread a while back something like this about remote starters and aftermarket radios messing with security. Just something to look into
Old May 13, 2014 | 09:11 PM
1FastBrick's Avatar
Custm2500's Rude Friend
P1626 Theft deterrent fuel enable signal lost. It is an Anti theft code
Google the code and follow the diagnostic tree to troubleshoot the issue.
Old May 13, 2014 | 09:18 PM
1FastBrick's Avatar
Aftermarket alarm system can cause issues.
I typically remove them to rule them out.
It could be anything from the ignition switch to the body control module.
The best thing to do is follow the diagnostics procedures for the code and see where the fault is.
Old May 13, 2014 | 10:03 PM
00blackz71's Avatar
I thought by turning off the vats in hptuners would eliminate any anti theft problems. Maybe I'm wrong on that but the code went away and hasn't come back.
Old May 13, 2014 | 10:14 PM
1FastBrick's Avatar
It may, but you need to do the diagnostics based on the code.
If there is a loose or broken wire It may cause the vehicle not to start.
https://www.performancetrucks.net/fo...-503550/page2/
Does HPT read Body codes or only engine and transmission codes???
Old May 13, 2014 | 10:36 PM
00blackz71's Avatar
I dont think it does body codes
Old May 14, 2014 | 03:52 PM
00blackz71's Avatar
Don't see any problems with the wiring. Googled the code and only thing I find on fixing the issue is to permanently ground the yellow/black wire and deleting vats like I already did but I dont see a yellow/black wire. Dont know where to start looking for the problem
Old May 14, 2014 | 10:44 PM
1FastBrick's Avatar
To properly diagnose an issue like this you need a scanner capable of reading Body codes. You also need to be able to see what's going on in other modules like the BCM.
https://answers.yahoo.com/question/i...1220620AAZ3fj7
wrb002
Aug 31, 2015 12:00 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
