truck will not start
Old Nov 26, 2002 | 07:28 AM
11 Second Club
Default truck will not start
I have a 02 silverado,and i have power,lights,radio,etc.
But it will not start not even turn over.
Anyone ever had this problem.
is it the igniton,starter, ground
tow truck is on its way to take it to the dealer
thanks for any help
Old Nov 26, 2002 | 08:34 AM
JWRENCH's Avatar
Default Re: truck will not start
It's that security thing, It'll start in a few hours. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 26, 2002 | 11:05 AM
99GMC Can's Avatar
My security acted up too. The wires from the ignition switch, which checks the key for authenticity and the switch both got changed. Mine would start and then quit just like it had no fuel.
Good Luck
Old Nov 26, 2002 | 11:16 AM
RED2K's Avatar
KICK IT
Old Nov 26, 2002 | 02:14 PM
eallanboggs's Avatar
If the engine will NOT turn over then it's NOT the SECURITY system because that system only disables the FUEL PUMP. It does NOT shut down the starter motor. It the engine won't crank you have to troulbeshoot the starter system. If that's OK then you put a wrench on the harmonic balancer bolt to see if you can spin the motor over by hand to make sure your engine is not seized. Those two things alone should keep you busy for a while.
Old Nov 26, 2002 | 02:29 PM
RED2K's Avatar
I had a 91 z28 that did the same thing. the secuirty light would flash but the car would do nothing at all. no starter no nothing
Old Nov 26, 2002 | 08:26 PM
GREGGO's Avatar
The positive terminal on stock AC Delco batteries tend to go to hell. Causing these symtoms. I know mine did.
Old Nov 26, 2002 | 08:35 PM
11 Second Club
Starter wire was loose.
Thanks for all the help GUYS <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 27, 2002 | 12:16 AM
JWRENCH's Avatar
<img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Nov 28, 2002 | 11:00 AM
99GMC Can's Avatar
Good to here it was a simple fix.
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
black6spdz
Jul 16, 2015 01:32 AM
