truck will not start
I have a 02 silverado,and i have power,lights,radio,etc.
But it will not start not even turn over.
Anyone ever had this problem.
is it the igniton,starter, ground
tow truck is on its way to take it to the dealer
thanks for any help
thanks for any help
My security acted up too. The wires from the ignition switch, which checks the key for authenticity and the switch both got changed. Mine would start and then quit just like it had no fuel.
Good Luck
Good Luck
If the engine will NOT turn over then it's NOT the SECURITY system because that system only disables the FUEL PUMP. It does NOT shut down the starter motor. It the engine won't crank you have to troulbeshoot the starter system. If that's OK then you put a wrench on the harmonic balancer bolt to see if you can spin the motor over by hand to make sure your engine is not seized. Those two things alone should keep you busy for a while.
<img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" /> <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
cams 98 silverado
Jul 31, 2015 07:36 AM
